Desktop Amplifier for RTiA1
crzycuyler
crzycuyler Posts: 16
edited April 2013 in 2 Channel Audio
I currently have my Denon AVR-3312 hooked up to my desktop setup amplifying my RTiA1s. I have to clear up some space, and I will soon be using the Denon AVR in another setup. What options do I have for a desktop amplifier? I have considered the AudioEngine N22. I can get the N22 at a great price. Will it give the A1s what they need? I am using them as near field monitors, essentially.
Thanks!
Post edited by crzycuyler on
  • Irrenhaus
    Irrenhaus Posts: 1,094
    edited April 2013
    How about one of this or hell maybe two running in mono there are some in Craiglist here in the Bay Area going for $99.00 a bit more on Ebay.
    http://www.parasound.com/ParasoundZ/zampv3.php
    Cheers
    HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
  • Mikey081057
    Mikey081057 Posts: 7,127
    edited April 2013
    I have a Qinpu A3, and folks marvel at the warmth.... I upgraded the tubes with some NOS. Couple hundred bucks cost
    Garage | Polk Monitor 5B's
  • Mikey081057
    edited April 2013
    http://www.polkaudio.com/forums/showthread.php?145179-What-s-on-your-desk
  • crzycuyler
    edited April 2013
    DSkip wrote: »
    Likely WAY out of your price range, but look at the Peachtree Nova. Its a nice all-in-one package that has everything but the kitchen sink.... and speakers. Used, they go for $750-800 though. If you're looking for a cheap solution, check out Parts Express for some T-amps, like this one: http://www.parts-express.com/pe/showdetl.cfm?partnumber=310-322
    That sure does sound nice, but you are correct. That price just doesn't make sense for me to spend on this setup. I am looking around $100 to $300. The T-amp thing is pretty much up my ally, though. I'll be checking these out.
    Irrenhaus wrote: »
    Cheers
    That's interesting. I like it. I'll be looking into it.
    I noticed this device before. I like to switch out components often so I would be afraid that the Qinpu A3 wouldn't always have enough juice.
    Thanks for all the responses.
  • crzycuyler
    edited April 2013
    DSkip wrote: »
    As an aside, it might be smart to find you an amp that isn't USB powered like that AudioEngine. Not sure if it would introduce noise as much as a DAC can, but I wouldn't want to risk it. I'd be looking for a wall wart.
    The USB is actually used to power external devices. It provides power. That's it.
  • sodablue
    sodablue Posts: 24
    edited April 2013
    I just use an integrated amplifier... I have a Rotel RA970BX on my computer, and a Cambridge Audio A300 on my wife's.
    I've been doing this for about 10 years now, after I'd replaced my third set of $150 amplified computer speakers that lasted a year.
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited April 2013
    crzycuyler wrote: »
    Thanks!
    What sources do you need to connect up? More than one?
  • crzycuyler
    edited April 2013
    Erik Tracy wrote: »
    Only my computer.
  • Erik Tracy
    edited April 2013
    crzycuyler wrote: »
    Only my computer.
    And if your computer has a good sound card with analog out, then I'm kinda with mikey081057 - a low powered, low cost tube amp - the RTiA1s are easy to drive, you are using them near field, you only need one input, and tubes will be a glowing warm compliment to the sparkle of the RTiA1s.
  • crzycuyler
    edited April 2013
    Erik Tracy wrote: »
    Thanks for the advice. I like the idea.
