MIT EXP Speaker Wire
Drenis
Drenis Posts: 2,871
edited April 2013 in Wanted (WTB) Classifieds
Curious if anyone has a single run of EXP 1 speaker wire? I have a run of just over 9' now but have decided to double up on the cable length so I can space my speakers apart more if given the opportunity. This is for my SDA signal. I use EXP 1 speaker wires for my stereo signal and would like to continue the same.
If nothing pops up then I guess I'll have to go a different route as EXP line is not produced any longer.
Let me know what you got!
Post edited by Drenis on
    pitdogg2 Posts: 27,563
    edited April 2013
    I have a 20' EXP 2 I'm not using....
  • Drenis
    Drenis Posts: 2,871
    edited April 2013
    Wow that's a bit longer than I need, but I wont rule it out. Do you know if the EXP 2 wire has two runs of 18 and two runs of 14 gauge inside?
    edited April 2013
    yes only the articulation poles are different. I believe they are two less than yours.
  • Drenis
    Drenis Posts: 2,871
    edited April 2013
    To be honest, I'm not even sure what that refers to with the cable technology. IMO ensuring constant gauging of wire and utilizing the same wire should yield me the best results I'm after. The EXP 2 wire may work for this purpose.
    PM me when you have time with what you're looking to get for that sucker shipped to R2L 0C8 (Canada).
