Good receiver for Monitor 65T?
RockerMan74
Amplifier Section Channel 7.2
Rated Output Power (1kHz, 2ch driven) 110W (8ohms, 0.9% THD)
Rated Output Power (20Hz-20kHz, 2ch driven) 95W (8ohms, 0.09% THD)
Dynamic Power per Channel (8/6/4/2 ohms) 140/180/210/250W
These are the specs for the amp in the Yamaha RX-V773. The Monitors are rated up to 200watts at 8ohms. It also has pre outs which is a plus. My listening habits are modest...I don't blow the windows out of the sill when listening to music. Think the receiver and speakers would work well with each other?:question:
Post edited by RockerMan74 on
You will be fine as long as you don't work the Yamaha to hard. How big is your room?Speakers: SDA-1C (most all the goodies)
Look for marantz receivers as well. Yamaha is also good ones.
My room is roughly 20'x30'. That really is just a guestimate because my tape measure is conveniently misplaced.You will be fine as long as you don't work the Yamaha to hard. How big is your room? -
I have been reading the polk education articles and I'm trying to figure out what wattage to keep in mind when playing music. I am definitely wanting pre outs for an external amp in the future. Looks like my only options for that feature is 7.1 at the least, which I will never use...yeah, I'm pretty sure of that. I have no need or want for that many speakers, but as a rule of thumb for 20-200 watt 8ohm speakers what is suitable wattage to look for? Anybody??
