$20/shipped.....Seconds........
Well, I screwed this Dim Bulb Tester up.
Let the cutting wheel get away from me, as you can see, bottom right corner, and upper left corner.
So I thought what the hey, instead of painting it, someone might like one cheap!
Used a new on/off switch (ivory), and new receptacle (white), I had laying around here just to complete it.
L is for "lamp" (I usually use a hospital grade receptacle with a green dot, no black marker).
This is not a hospital grade receptacle.
Missmatch second, but pretty cheap considering it is shipped.
It is still pretty sweet and very handy thing to have (just throw it in a drawer).
I have made a few recently, and most people like to have them when they go to look at a component listed on CL for instance, and can test it without harming it.
Wire is soldered to the IEC input, everything is heatshrinked, and I will throw in that cable (about 20" long) if you need it.
Any computer power cord will work.
Aluminum box (grounded to the box also).
I figure it will cost at least $8 to ship.
$20/shipped!
  • Systems
    Systems Posts: 14,872
    edited March 2013
    $15/shipped.
    Not going to Karma it.:cheesygrin:
    Testing
    Testing
    Testing
  • Moose68Bash
    Moose68Bash Posts: 3,843
    edited March 2013
    I'll take it with pleasure!
    Just let me know how you want me to get payment to you.
    Thanks,
    Phil
  • Systems
    edited March 2013
    Thanks,
    Phil
    Its yours.
    Testing
    Testing
    Testing
  • Systems
    edited March 2013
    sold!
    Testing
    Testing
    Testing
  • nspindel
    nspindel Posts: 5,343
    edited March 2013
    Silly question. What does this do?
  • michael1947
    michael1947 Posts: 775
    edited March 2013
    +1 for what's it do.
    Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
    Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's.
    Toolfan66 Posts: 18,161
    edited March 2013
    +2 for whats it do?
  • nspindel
    edited March 2013
    Whew! I'm not the only one!
  • bmbguy
    bmbguy Posts: 416
    edited March 2013
    It's a test tool.
    http://antiqueradio.org/dimbulb.htm
    And it looks pretty good, Pepster!
    edited March 2013
    Nice!!!!
    Thanks!!!
  • Systems
    edited March 2013
    Sorry Larry, guess I should have explained more.
    It is mainly for the "vintage equipment" guys/gals.
    For example, I bought an 8 tube 1952 tube amp the other day for $13 because it would not turn on.
    Plugged it into the DB tester and instantly knew all was good with the transformer (if bad, tranny fumes can be deadly on older amps), filter caps, and there was no short in it, all from just plugging it in the DB tester.
    So I knew it was something minor, and the amp was not a total loss.
    Replace a few caps, and then use the DB again to test my work.
    Poor man's variac, current limiting, tester.
    Testing
    Testing
    Testing
  • nspindel
    edited March 2013
    Ahhhhh. Got it, thanks for the explanation.
  • Systems
    edited March 2013
    Sorry, 1 more post:
    Simple explanation: the current required for a component to turn on, is going through the light bulb filiment first.
    Thus the higher the wattage lightbulb, the more current sent to the component.
    If there is a major short in the component, the bulb will tell you first (within a couple of seconds), and will burn out before before feeding said short.
    Worse case, your out a .20 lightbulb, instead of a $200 transformer, or worse a fire.
    Testing
    Testing
    Testing
