bi amping mm455
paul mx3
what ratios would you use running the mm455 comps active(2 amps)i was considering a jl audio 300/2 which i already have and maybe getting a 300/4 to run the tweets off 2 channels and using the other 2 for rear fill on some diamond m361i coaxial speakers....
would the tweets be ok run at 75 rms each and the mids at 150 rms each....i want the ratios to sound right....i am aiming at a purely sq setup.....
