tc80i in ceiling mounting position
When mounting the tc80i in ceiling speakers as surrounds,should I turn one 180 degrees to keep the tweeters on the same side due to the offset of the tweeter? I think I will but I just ordered them and don't have them yet to see if there is a difference.
You want to orientate the speakers so that you can point your tweeters towards the listening area (main listening position). Base is unidirectional but tweeters need to be focused.
ChipSharp LC-80uq17u
Denon 4520ci Receiver
OPPO BDP-203 Blu-Ray Disc Player
Monster HTS 3600
Polk RTi-a7 (fronts)
Polk CSi-a6 (Center)
Polk TC-60i (Rear & Surround Rear)
HSU Research VTF3-MK4 (Sub)
Logitech Harmony elite (Remote) -
Go online and pull up the user manual, it should answer your query.If you can't hear a difference, don't waste your money.
Great point decal. What I posted above is what I did with my tc-60i's.Sharp LC-80uq17u
Monster HTS 3600
.Go online and pull up the user manual, it should answer your query.
The manual says nothing about rotation so I guess as long as I mount them tweeters up or tweeters down I should be fine....IThey are mounted in an angled ceiling to be used as side surrounds l will play with them and post my results Thanks...
