Center channel for LSIM703
Etelvina
Etelvina Posts: 8
edited April 2013 in Speakers
I have recently bought a pair of LSIM703's. Excellent speakers. My next upgrade is a new center channel. According to the Polk website, LSIM704c is the proper center channel. However, I can not find any good deals on that speaker but I can find good deals on the LSIM706c. Would I get proper timbre matching with the 706 or should I just wait patiently for a 704?
  • monepolk
    monepolk Posts: 1,154
    edited March 2013
    I don't own that particular speaker, but the 706 is the same series and would be a perfect timber match.
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited March 2013
    I'd say the 706 is more of a match than the 704 is.
  • Etelvina
    Etelvina Posts: 8
    edited March 2013
    Leroy,
    A couple of questions;
    1. Why would you think the 706 is a better match?
    2. During movies, would the 706 "overpower" the 703s? As a result, all I would hear is the center channel.
  • falconcry72
    falconcry72 Posts: 3,580
    edited March 2013
    leroyjr1 wrote: »
    I agree.
    I've listened to both, and the 706 is the better speaker for sure. Both will match perfectly, but the 706 has better bass.
    I'll sell you my 704 if you want it. :biggrin:
  • falconcry72
    edited March 2013
    Etelvina wrote: »
    Leroy,
    because it uses the same woofer as the 703's.
    No, that does not make sense on many levels. First off, a large speaker is not inherently louder than than a smaller speaker; in fact, a larger speaker is likely to be less sensitive, so it would be quieter given the same amplification; however, whether it's louder of softer is completely moot because you control each speaker's volume (channel level) with the AVR.
    cheers
  • leroyjr1
    edited March 2013
    Etelvina wrote: »
    Leroy,
    Both the 703's and 706 center has the same drivers while the 704's are smaller. No it will not over power the 703's. Once calibrated they'll blend perfectly.
  • Loud & Clear
    Loud & Clear Posts: 1,538
    edited March 2013
    Another 703!
    Two Channel Setup:
    Speakers: Wharfedale Opus 2-3
    Integrated Amp: Krell S-300i
    DAC: Arcam irDac
    Source: iMac
    Remote Control: iPad Mini
    3.2 Home Theater Setup:
    Fronts: Klipsch RP-160M
    Center: Klipsch RP-160M
    Subwoofer: SVS PB12NSD (X 2)
    AVR: Yamaha Aventage RX-A2030
    Blu Ray: Sony BDP-S790
    TV Source: DirecTV Genie
  • Lan077
    Lan077 Posts: 31
    edited April 2013
    Both the 704c and 706c will blend perfectly. The nice thing about the 704 is they didn't cut out the mid range driver like most companies do on their smaller center offerings For all practical purposes the 704 is just as good as the 706. If you can find a deal on the 706 from an authorized dealer though go for it. Make sure you have the room, the 706 is a very large and heavy speaker!
  • WLDock
    WLDock Posts: 3,073
    edited April 2013
    Lan077 wrote: »
    That is it right there. The tweeter and mdrange are the same drivers and that is the major area of concern. All three of these are from the same series and have the same efficiency rating...88 dB...for the whole LSiM line! They all just have lower -3dB down points. With the DSP power of most systems these days combined with the work that manufacturers put into making all their same series speaker work better together....these are really discussions from yesteryear. With the LSiM series Polk has made it easy! 704 vs. 706 is splitting hairs...very fine ones! If you have room for the BIG one...get the BIG one...if not get the smaller one!
    Polk Audio wrote:
    "Timbre-Matched Series
    The LSiM main, center and surround loudspeakers are timbre-matched for a seamless speaker to speaker blend, so vital for achieving the incredible realism and enveloping surround effects found in the best multi-channel systems."
    5.2 A/V Setup | OLED TV - Sony Bravia XR A80J 77" | Source - Fire TV 4K Max, Wiim Pro | AVR - Anthem MRX 520 | Integrated - Musical Fidelity A5 | Speakers: Main - Boston Acoustics VS 336 | Center - Boston Acoustics VS 325c | Rear - Boston Acoustics VR-MX | Sub 1 - Boston Acoustics VPS 210 | Sub 2 - HSU VTF-2 mk3
  • Scooterp7
    Scooterp7 Posts: 21
    edited April 2013
    Another 703!
    That would be my thought.
    Any reason (besides aesthetics), not to use the 703 as a center?
