Tube question for Dodd phono and preamp
dromunds
dromunds Posts: 10,031
edited March 2013 in 2 Channel Audio
I'll be getting a battery phono stage and also a preamp from Gary Dodd. The phono stage uses four 6DJ8-family tubes. I currently have a Dodd ELP preamp with two 1950's Amperex Holland Bugle Boy D getters that I'll put in the new phono stage, and I recently got another pair of Amperex D getters, so hopefully I'm set for the phono stage tubes. My question is: the preamp uses one tube, anybody have any thoughts on what would be a good combination to use with the Amperex tubes I'm planning to use in the phono stage? Should I stick with an Amperex? Would another single D getter be a good way to go, or what about a 6922 Amperex gold pin? Would a comparably-priced TFK be compatible to the BB's I'm using in the phono stage, and if so, which one would be recommended? Any other ideas what single tube would jive well with the BB's in the phono stage? I'm using a solid state S.A.E. amp. I'm pretty new to tubes so I appreciate any suggestions.
Post edited by dromunds on
  • zingo
    zingo Posts: 11,258
    edited March 2013
    Are you getting his preamp, or his tube buffer preamp?
    If it's the single tube buffer, you can use the following tubes in it among others: 6922, 6DJ8, 6H30, 6N1P, 7308, CCa, PCC88, 6H23, CV2492, PCC88, 7DJ8, E188CC.
  • dromunds
    edited March 2013
    Zingo, its a tube preamp with selectable gain, not the tube buffer which I understand has no gain. If I went to a 6H30 for the tube preamp, do you have any suggestions?
  • Face
    Face Posts: 14,340
    edited March 2013
    dromunds wrote: »
    I use these: http://www.partsconnexion.com/NOS-68615.html
  • dromunds
    edited March 2013
    Face: I appreciate the advice.
    heiney9 Posts: 25,221
    edited March 2013
    They call it tube rolling for a reason. No right or wrong, really. Just whatever combo floats your boat. That's part of the fun of tubes.
  • zingo
    zingo Posts: 11,258
    edited March 2013
    dromunds wrote: »
    Any of the above tubes should still work, and there are great tubes in all price ranges. the 6H30 seems to be well made at any price point as there were very few manufacturers. Even the $30 version should give you a good idea of the sound of the tube, and how it differs from the 6DJ8 variants. You probably can't go wrong with the EH version if you want to try the tube.
  • usp1
    usp1 Posts: 207
    edited March 2013
    I have the same Dodd pre with adjustable gain and I use the NOS Reflektor 6H30P-DR "super" tube. After some tube rolling I settled on this tube. This should certainly be one of the tubes you should try if you plan on tube rolling.
  • dromunds
    edited March 2013
    Thanks much, fellas. usp1, nice to hear about the tube you settled on, will check it out for sure.
