New pc rebuild finally complete
fbm211
After waiting over a week to get a new mobo and take care of the P8Z77-V RMA and the Gskill ARES 1866 RMA as well I finally got the new memory (Gskill sniper 1866) and I decided to go with the ASUS Maximus Formula ROG board.What a nice mobo and the onboard supreme FX sound isnt to bad either.Getting the mobo to fit took a bit of time as it is a little bigger than the standard ATX but I got it done and so far its running pretty good.But cable management is going to be a problem since to board is covering a vital cutout for the 24 pin cable.Ill have to get a full tower HAF or thermaltake nvidia case eventually.
Idle cpu temps are pretty good at 30c (4.2ghz)Once I get some benchmarks installed I can get some full load temps and start to get the cpu up to 4.6-4.8 hopefully.
SPECS:
NZXT M59 case
XFX 850 black edition PSU
Asus Maximus V Formula mobo
EVGA GTX 680
Gskill Sniper 1866 8gig kit
VelociRaptor 150
Asus DVD burner
Noctua DH-14 cooler.
I will also eventually replace the noctua with a thermaltake H220 water cooling system for the CPU and motherboards fusion thermo water cooling option.And some red case lighting.
SPECS:
NZXT M59 case
EVGA GTX 680
VelociRaptor 150
Asus DVD burner
SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
Post edited by fbm211 on
I do believe I will get the soundblaster ZX SBX PCIE Gaming Sound CardSDA-2BTL with custom IC
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
Clean up those cables. Pull all those cables through the side of the case. Nice build btw. Here's my current rig using a NZXT Phantom.
Nice one sherardp. What happened to your coolermaster cube case?
I've made a lot of changes to my build. I had a lot of problems with the maximize V board so I got a gigabyte sniper 3 and its awesome. I also installed a custom liquid cooling system. I post some pics if I get a chanceSDA-2BTL with custom IC
Those Velociraptors are burly HDD's. I remember when the regular Raptor first came out, completely demolished non SCSI drives.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Still going strong here with the Phantom. Have not made any changes at all. Nice to see you guys still at it.Shoot the jumper.....................BALLIN.............!!!!!
Here is the loop I installed
This was taken while I was leak testing.All the wires are now under the cover.
I intend to transfer everything into the HAF stacker (modular case) when it comes out.Then Ill be able to add a couple alphacool UT 60 RADS,and add another loop to put my pair of 680s under water.SDA-2BTL with custom IC
