Sigh, a question for you audio/IPOD hookup guru's..
starkiller
Put a treadmill in our guestroom so obviously some tunes were in order. Have a 5cd player into a dac into the intergrated. Have a tube buffer and an IPOD so bought a adapter to hook the IPOD to the buffer and then to the integrated. The cd sounds fine but very very low volume on the IPOD connection, what I be doing wrong?
thanks as usual!
thanks as usual!
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
Post edited by starkiller on
Have you tried turning up volume on ipod, if you have then try bypassing buffer.Speakers: SDA-1C (most all the goodies)
Turned the volume on the ipod all the way up and it got better but still not loud enough, took the buffer out of the equation and poof and voila!! We got tunes
So i guess the buffer will go on the market...thanks for your help!
