Amp or Receiver Bi-Amp
Velocitydreamer
I was wondering if an Emotiva XPA-200 would be better for my Rti10’s. I am currently running my Onkyo TX-NR709 bi-amped to them. Now, 110w+110w=220w and that would be better than the 150w of the Emotiva, but I get the feeling that calculation is based upon “stupid math” and not all needed variables for real world results lol. Someone break it down for me, if possible, how the Emotiva is (likely) better than my Onkyo bi-amped. I’m sure impedance comes into play somehow (?) Thank you! :cheesygrin:
Also, I plan to someday upgrade to a pair of Lsi25's or Lsi15's. I know the receiver is 4ohm capable, and I... BELIEVE... it is capable of bi-amping in 4ohm? And I'm guessing that the 15's would be bi-ampable, but not the 25's. With that in mind, would it be better to get the 15's, bi-amp, and get 1/2 good quality sub(s)? I listen to a LOT of music, but also watch a LOT of movies, so I guess 50/50. I know music tends to favor towers with full range vs towers + seperate sub. Price entirely aside between the 25's & 15's.
LivingRoom
Source: HTPC
Display: GT720 (on the wall)
Receiver: HK AVR1700
L/R: RS850 Signature
Center: RSC200 Signature
SS: Onix Rocket ELT DPA
Sub: SVS PB1-ISD
2 Channel (in the making)
Source: TBA
Amplification: TBA (Integra 2.1 interim)
Speakers: AV123 Onix Rocket Strata Mini
Source: HTPC
Sub: SVS PB1-ISD
Source: TBA
Post edited by Velocitydreamer on
Almost any separate amp is better for driving speakers than a receiver, just because of their design compromises.
I really like the LSi25s because they not only have powered subs built-in, but that also makes them easier to drive with an amp.
Yeah, not long ago I had a set of RT3000P's and loved them. With the tight, heavy hitting bass they produced alone, I sold both my Klipsch RW-12's lol (now I kinda wish I'd have kept one)... I get the feeling the Lsi25's won't punch as hard, or fill the room with as much air moving pressure? (my livingroom really isn't that big, but I don't care :P ) I want a lot of smooth dropping, low bass, but wouldn't mind sacrificing a bit to run a system without seperate sub. I'll probably do as you said and run the 25's... in that case, I may just stick with my receiver, as the 25's will have the bottom end powered by the internal amp, and it's more than adequate to power any side and rear bookshelves I get I imagine.LivingRoom
Source: HTPC
Sub: SVS PB1-ISD
Source: TBA
Speakers: AV123 Onix Rocket Strata Mini -
FYI, because your Onkyo's amp section draws from a common store of power, 110w + 110w doesn't equal 220w unless all of the other channels are silent. That's why you'll see people saying that bi-amping from a receiver is pointless. I still think you'd benefit from adding a separate amp, and I damn sure wouldn't run a 4 ohm speaker off the Onkyo and expect it to reach its potential. Changing the Onkyo to 4 ohm operation basically turns on current limiting so the AVR doesn't overheat from the extra load, and an external amp capable of actually handling 4 ohm speakers would be preferable.Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
So you're saying that an Lsi25 would run best off an external amp? Also, drawing from a common store of power, using a 7.1 receiver for a 5.1 setup, shouldn't the store used for those extra 2 channels be used in addition to the front channels. I would figure with that logic, you still equate to 110+110. I'm sure I'm missunderstanding, which is why I'm explaining my current understanding of what you said, so that I can be corrected
LivingRoom
Source: HTPC
Sub: SVS PB1-ISD
Source: TBA
In real world use when you are watching a movie, all channels are never called upon to deliver full power (or significant power for that matter) simultaneously. Mass market manufacturers take this into account in their designs. Why build a receiver with a power supply large enough to power all channels to their maximum (with its extra cost) when it will never be needed in actual use ? The solution is to make the power supply just large enough to power two or three channels simultaneously at any given time. This helps make AVRs more affordable, despite all the latest bells and whistles.Velocitydreamer wrote: »So you're saying that an Lsi25 would run best off an external amp? Also, drawing from a common store of power, using a 7.1 receiver for a 5.1 setup, shouldn't the store used for those extra 2 channels be used in addition to the front channels. I would figure with that logic, you still equate to 110+110. I'm sure I'm missunderstanding, which is why I'm explaining my current understanding of what you said, so that I can be corrected
Look at this Onkyo TXDS696 rated at 100W x 5. Does it look like a 500 watt class AB amp inside ? No. Under bench test, it delivered 151 watts into one channel at 8 ohms, and 46 watts into all five channels simultaneously at 8 ohms. The power supply does not have the current capability to deliver 500W. This is typical of mass market receivers. In actual use on movie material, this AVR never sounded like it was running out of power.
If you want to bi-amp, get a good multichannel amp, couple of 2-channel amps or monoblocks.
Party System: Laptop #2 | Audioquest Dragonfly USB DAC | Technics SU-A6 | Acurus A-250 | Radio Shack 15-band EQ | Pioneer SR-9 reverb | Cerwin Vega DX9's | Dayton 100° x 60° horns with titanium HF/MF compression drivers. -
Great info and explanationSharp LC-80uq17u
Denon 4520ci Receiver
OPPO BDP-203 Blu-Ray Disc Player
Monster HTS 3600
Polk RTi-a7 (fronts)
Polk CSi-a6 (Center)
Polk TC-60i (Rear & Surround Rear)
HSU Research VTF3-MK4 (Sub)
Logitech Harmony elite (Remote) -
Thanks a TON Glen, that makes a lot of sense... just needed someone to shed light on the "why's." Thanks again!LivingRoom
Source: HTPC
Sub: SVS PB1-ISD
Source: TBA
One last noob question that has had me wondering for a long time... the Rti10's are about 3-4ft away from the TV, and I have them pointed towards the most common seated position in the room... should I do that, or should I have the backs of the speakers parallel to the wall? Also, I thought I read something about the Rti10's either needing to be pulled out from the wall, or closer... coulda swore it was pulled out from the wall, and I usually run most my speakers closer to the wall. Clarification on this matter would be awesome, thanks a ton for your advice all!LivingRoom
Source: HTPC
Sub: SVS PB1-ISD
Source: TBA
