Replacing tweeter in CSi40
Hey peeps,
I would like to get some feedback on replacing the tweeter in a CSi40 with ether a Vifa or Scan Speak tweeter. And yeah, I know there would be some possible matching issues with my 150's in regard to the upper limits, and some may ask, why would I even want to do this. Well, the reason is hmmm...... um....... I'm a tweaker, I like making things better. lol Hopefully better anyway. Ok, as for feedback, I quess what I would like to hear is, what all would I need to take into account? Other than the more obvious like size and stuff. I'm thinking crossover points, actual material the replacement is made of, complications, in general, aspects I might miss.
Terry
Terry
Post edited by Terrax on
Terrax,
Know you've been around here to read many times that the first concern is the "new" tweet's performance with the cross-over in the i40. So I'm guessing you're determined to try one or more replacements (kinda the definition of a "tweaker").
So try a couple... you can always go back.More later,
Tour...
Vox Copuli
Just a note of caution from a guy who's done a bit of DIY speaker-building: I'm all for tweaking and experimenting, but it's unlikely that you will improve upon the design simply by swapping in a different tweeter. The crossover is everything, really, and there are too many variables that change when you swap drivers. It'd just be a shot in the dark, without measuring equipment.
Especially if you're thinking of spending the $$$ for Scan-Speak, I'd have to say it's not worth it unless you're willing (and able) to measure the mid woofers and re-design the whole crossover.
A better tweak might be to upgrade crossover components.
Just my opinion!
Good luck,
Jason -
Thanks for the input. What I hope to find is a replacement I can match as close as possible to the stock spec's.
