is this sponge as good as acoustic sponge?
stevethebrain
stevethebrain Posts: 49
edited March 2013 in DIY, Mods & Tweaks
I stuffed a couple pillows behind the main speakers an heard a slite improvement attached image.
I would like to have a few acoutic panels directly behind the main LRC speakers then the first reflection points on side walls my right front main speaker is a tad close to the right wall approsmently 10" I would like sponge on this side wall to prevent reflections.
I plan a QRD type diffuser on the back wall surrounded w/ the same sponge.
http://www.walmart.com/ip/La-Z-Boy-BigSleep-3-Convoluted-Foam-Topper/22991618?findingMethod=rr#rr
I would prefer to use sponge instead of stuff like fiberglass or Roxul rockwool (don't want to be itching and breating fiberglass). plus the exposed sponge looks kindof cool.
I'm kindof leaning toward this walmart sponge because it's white (unlike 99% of actualle acoutisc sponge) it's inexpensive and it's thick.
any tips is appreciated.
STB
Samsung PN58C500/Amp: Yamaha RX-V465/Polk DSW1KProSub/DefTECH SM450/C1CC/Pro80/Sony BPX37 BD/Magnavox515/ HTPC-CPU: I3 550, 3.2 GHz/Mobo: Intel H57/RAM: 6GB DDR3 1333/HDD: 1TB/2TB Internal, 1TB external/Tuner: 1600-950 Haupague/W7 64 OS Remote: Harmony 700
  • stevethebrain
    edited March 2013
    here's a image of the rear wall difussor (in the middle of rear wall) I plan surounded w/ sponge.
  • stevethebrain
    edited March 2013
    also planning upper corner bass traps in all 4 corners simiairl to this.
    STB
  • stevethebrain
    edited March 2013
    notice in above image how small the panels are behind the mains what do you Guy's think about there size they appear kindof small.
    STB
  • stevethebrain
    edited March 2013
    Dude are you for real I'm asking about the sponge not the pillow.
  • decal
    decal Posts: 3,204
    edited March 2013
    STB
    Steve, no offense, but until you get that clusterf$%^ straightened out, noting is going to help your sound.
  • oldrocker
    oldrocker Posts: 2,590
    edited March 2013
    seen the pillow comments comin a mile away...
  • zingo
    zingo Posts: 11,258
    edited March 2013
    PLEASE stop calling it a sponge... Use acoustic panel, foam, defuser, etc.
    Adjusting the placement of your speakers will be the first improvement in your system; free placed speaker stands would be an improvement. Make sure they are the same height, and equal distance from the TV; also make sure your listening position is centered between the speakers. Based on your pictures, even if you adjust the placement of your speakers, you will have a lot of reflections off of the TV sides, and the shelves and side wall on the right side.
    If after that you are still wanting to do acoustic treatments, what are you trying to accomplish with them? Acoustic panels/foam on behind the speakers probably won't make much of a difference because your speakers are not bi-polar and reflecting off the rear wall. You will have reflections of the side wall to the right, so that could be addressed.
    What are you trying to accomplish with the bass traps?
  • bklynNupe
    bklynNupe Posts: 728
    edited March 2013
    Not to high jack but I have a quick question on the subject of pillows .:lol:
    On the right side of my listening room is a large sectional couch with plenty of pillows. On the far left side is the wall and a window. I'm on the top floor so I don't have anything on the window. My question is do couches, pillows, etc. negatively impact the listening space if these objects are not symmetrical to the room? The reason I ask is I've noticed many of these room treatments seem to have some sort of symmetry when placed on the walls of a room.
    emotiva xpa-2
    emotiva xpa-3
    Denon 3312ci
    Rtia9 /csia6 / FXi A6
    Samsung LN46A650
    SVS PB-12-NSD sub
    Audio Research SP-9 MKIII (GNSC mods)
    W4S ST250
    Lsi 9 (mods)
    W4S DAC-2
    Mac Mini
    Audio Aero Prima CD player
    Pro-Ject debut
  • evhudsons
    evhudsons Posts: 1,182
    edited March 2013
    I've been so busy I haven't been back on the forum until now, but my first post read was this one. Awesome! I applaud fully your wanting to treat the room acoustics, but certainly you can tweak the system as it is by simply better placements. I love the picture by the way, serious attempts at a good resolution! Whatever works in the interim!
    Love it.
    Polk Audio SDA CRS+ crossover 4.1TL by Trey/VR3 (Rings and custom stand by Larry)-Polk Audio SDA SRS2 crossovers by Trey/VR3Parasound HCA1500aYamaha rxa-3070 with musicast-Celestion SL6S presence,- Monitor Audio Silver rx2, , surround backNHTsuper1's surround, Parasound 1500, Marantz 2230/Technics 1200mk2 Gamertag: IslandBerserker I am but a infinitesimally small point meeting the line of infinity in the SDA universe
  • bklynNupe
    edited March 2013
    Great, makes sense. Thanks!
    DSkip wrote: »
    That's because there are specific areas you want to treat and speakers are more often than not placed symmetrically in the room. If they weren't symmetrical, you wouldn't want your treatments symmetrical either. Done right, the only thing you're addressing is major reflection points and bass reinforcing areas (corners and such).
    People like symmetry and patterns, hence the results you see.
    emotiva xpa-2
    emotiva xpa-3
    Denon 3312ci
    Samsung LN46A650
    SVS PB-12-NSD sub
    W4S ST250
    Lsi 9 (mods)
    W4S DAC-2
    Mac Mini
    Pro-Ject debut
    gudnoyez Posts: 8,229
    edited March 2013
    Yeah I think I would ditch the dirty pillow, would'nt want to entertain or have guests over with that. I would go another route good luck finding the right acoustic panels.
  • skrol
    skrol Posts: 3,499
    edited March 2013
    I prefer sofa cushions myself. I actually did try this and was surprised at the difference. Just don't let the wife see.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • stevethebrain
    edited March 2013
    zingo wrote: »
    Adjusting the placement of your speakers will be the first improvement in your system; free placed speaker stands would be an improvement. actualley stands isn't a option. the left speaker would most likly be knocked over.
    actualley the left speaker protrudes a 1" in front of the TV. I'm in the process of making a new shelf for the right side and elimimate or shorten the shelf directly above.
    If after that you are still wanting to do acoustic treatments, what are you trying to accomplish with them? the pillows do make it sound better more detailed.
    STB
  • stevethebrain
    edited March 2013
    yes the right speaker is a tad close to the wall I taped a piece of 1" packing foam and it made a nice suttle improvement.
    STB
  • stevethebrain
    edited March 2013
    note the angle of the image it was taken from the listening and viewing position (which is'nt centered inbetween both speakers) I know this is'nt ideal so I've angled eack speaker to the left.
    each main speaker is 12.5' from my head. the right is 13'.
    STB
  • stevethebrain
    edited March 2013
    couple more images of left speaker
    so is this speaker still producing reflections off the side of cabinet?
    sm450sideviewcloseup.jpg[/
  • stevethebrain
    edited March 2013
    Guy's I'm in the process of adjusting the speakers positions allready adjusted thee center.
    will post images of main relocations this week. I still plan the acoutic treatment so I ask is this sponge just as good as the expensive
    acoutisc sponge? the last review from Wallmart writes he used it for treatments and it worked good.
    STB
