5.1 or 2.2
KLapinas
edited March 2013 in Speakers
I am debating if I should change my system in my family room.
My current setup is an Onkyo tx-sr304, with Rt400, cs245i, paradigm dipole surrounds and an HSU sub.
Equipment setting around is a Cambridge Audio azur 540a series 2, azur 540c series 2, Vienna Acoustics Bachs, and
two REL q201e subwoofers.
Thoughts?
  • Loud & Clear
    edited March 2013
    I run a 3.2 and really enjoy it. I find that a quality center speaker does add to my ability to hear dialogue with more clarity. And two or more subwoofers will always be a part of my theater setup. Bass is everywhere instead of to one side of the room. I would recommend a CS400 for your center. I used to own the CS245i and then the CS400i. Big difference.
    Two Channel Setup:
    Speakers: Wharfedale Opus 2-3
    Integrated Amp: Krell S-300i
    DAC: Arcam irDac
    Source: iMac
    Remote Control: iPad Mini
    3.2 Home Theater Setup:
    Fronts: Klipsch RP-160M
    Center: Klipsch RP-160M
    Subwoofer: SVS PB12NSD (X 2)
    AVR: Yamaha Aventage RX-A2030
    Blu Ray: Sony BDP-S790
    TV Source: DirecTV Genie
  • KLapinas
    edited March 2013
    Too big for my space. Looks nice and I am sure it sounds good.
  • ScottyDugs
    edited March 2013
    Loud n Clear, how big is your room with the 3.2 and does 3.2 still work well with a larger room?
    My SETUP
    AVR: Denon 1913
    Main L/R: Polk LS90's
    Center: Polk CS350LS
    Side Surrounds: Polk LS/FX's
    Rear Surrounds: Polk RT/FX's
    Subwoofer: Polk PSW300
    100% Cinematic Adventures, 0% Music
  • Loud & Clear
    edited March 2013
    Smallish area. If I moved the gear into a different room I would almost certainly employ surrounds. Would 3.2 work in a larger room? I don't see why not. I also believe that if you can do it, that using a bookshelf speaker in its native orientation is preferable to a 'center' speaker. I use a short stand that angles slightly upwards at the front to aim the speaker to ear level.
    Two Channel Setup:
    DAC: Arcam irDac
    Source: iMac
