Setting Anti Skate ??
Toolfan66
Toolfan66 Posts: 17,991
edited March 2013 in 2 Channel Audio
Tracking force = Anti skate if memory serves me right. Maybe adjust it a little here and there if needed..
As I goggled it boy it sure seems like this topic could be close to a cable thread. Well I don't want that but I am open to hear the thoughts of others that have their why of doing it, and maybe learn a little more about setting it without breaking the bank to do so.
So thoughts?
Post edited by Toolfan66 on
  • quadzilla
    quadzilla Posts: 1,543
    edited March 2013
    If you have your anti-skate set equal to your tracking force, you'll generally have too much anti-skate, but this varies by cartridge and stylus design. In other words, there is no one good answer.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • [Deleted User]
    [Deleted User] Posts: 7,658
    edited March 2013
    The idea behind anti-skating adjustment is to provide even stylus pressure on the two groove walls, but because of having to angle the headshell in order to achieve better linear tracking there ends up being additional pressure on the inner groove wall. One approach, I remember, was to use a blank disk, one that had a groove-less band. You were to put the stylus down in the middle of this band and adjust the anti-skating until the stylus didn't move inward or outward. However, this didn't take into consideration the effects of differing groove friction generated by the offset headshell. Another approach is to temporarily wire one channel of your cartridge opposite in polarity to the other channel (swap the red and green wires at the back of the cartridge). Then begin playing a monophonic record, choose a spot near the middle of the record. Adjust the anti-skating for the lowest audio level. This should result in optimum groove pressure under a real record playing conditions.
    Regards, Ken
    edited March 2013
    Thanks Ken,
    Finding a smooth side lp is not easy.. Last time I set up my TT i just adjusted it here and there till I felt it sounded it's best and never had a problem. But since I ordered a new cart I thought I would revisit the set-up..
    SCompRacer Posts: 9,087
    edited March 2013
    I found the HiFi News Analogue Test LP very useful. It has tracks for setting anti skate. It is also supplied with a nice alignment protractor.
    media.nl?id=17918&c=ACCT106601&h=4f697ea0ef5634a83b0c
  • [Deleted User]
    edited March 2013
    No problem, enjoy your new setup!
  • agfrost
    agfrost Posts: 2,463
    edited March 2013
    Toolfan66 wrote: »
    Thanks Ken,
    Looks like I found a use for "side 4" of my 3-sided Big World LP by Joe Jackson!
    Jay
  • doctor r
    doctor r Posts: 837
    edited March 2013
    I have found that about 50% of the VTF setting is a good starting point for most anti-skate or "bias" settings. The 1:1 anti-skate to VTF ratio that was recommended in the past usually is excessive and makes the reproduction not nearly as dynamic as is possible (and desired). I start at or below the 50% and then adjust by ear. If you have an album you know well you can carefully listen to the fidelity of each channel simultaneously and slowly increase the anti-skate and re listen. Initially the left channel will be stronger, clearer and more dynamic and then the right begins to emerge. When you have exceeded the best bias setting both channels seem to collapse and the music losses it's magic. Back up a little, fine tune a little, and you should be good. Takes a little patience, but you will be richly rewarded in the increased fidelity of your vinyl playback.
    Rick
    integrated w/DAC module Gryphon Diablo 300
    server Wolf Alpha 3SX
    phono pre Dynamic Sounds Associates Phono II
    turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
    cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
    speakers Rockport Mira II
    cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
    rack Adona Eris 6dw
    ultrasonic cleaner Degritter
  • Sprags
    Sprags Posts: 120
    edited March 2013
    Remember putting a penny on the cartridge to 'help' the stylus track better. With a penny you don't need to worry about anti- skating too much.
    edited March 2013
    Haha I was thinking about that today..
    edited March 2013
    I don't need no stinkin' pennies; I have an aluminum body!:biggrin:
    Note: No records were plowed with this mod due to appropriate counterweight used.:smile:
