Crossover help
crcostel
crcostel Posts: 13
edited March 2013 in Speakers
I ran audyssey on my new setup and it recommended crossovers at 40hz for everything across the board. I know that is way too low - anyone have recommendations?
Current Setup
AV: Onkyo TX-NR709
Front: Polk TSi300
Center: Polk Monitor CS20
Front Wide: Polk Monitor 30ii
Surround: Mordaunt Short Carnival 1
Subwoofer: Mordaunt Short Carnival 9
  • rpf65
    rpf65 Posts: 2,127
    edited March 2013
    It just determined that your other speakers can go a little below 40 Hz comfortably. You can go to the speaker set up screen,and set the cross over higher, if you want to. Most will usually run them at 80. You can set you speakers at a higher freq after Audysey set them, but never lower.
    F1nut Posts: 52,371
    edited March 2013
    80 Hz is the setting most folks use.
  • B Run
    B Run Posts: 1,888
    edited March 2013
    80hz is the standard and even if your speakers can play lower. It'll clean up the sound and take a load off your amplifier, so it's not trying to handle notes the sub can do a better job of reproducing.
  • crcostel
    crcostel Posts: 13
    edited March 2013
    Would it make sense to set the center channel higher since its mainly dialogue?
    Current Setup
    AV: Onkyo TX-NR709
    Front: Polk TSi300
  • rpf65
    rpf65 Posts: 2,127
    edited March 2013
    I personally think it's better to set all cross overs equally. Many will disagree wit that. The freq that you select isn't a hard cutoff point, but the beginning of a slope.
    For instance if you select 80 hz as your cross over point, that is the point where the AVR starts sending the signal to the sub. The other speakers will also receive the signal. All of your speakers may receive that signal, but to a lesser degree.
    Just numbers here, but an example. Cross over set to 80, sub will only receive signals at or below 55 hz, but at 60 hz other speakers receive 30 percent of normal signal strength.
  • ScottyDugs
    ScottyDugs Posts: 91
    edited March 2013
    it calibrated my surround crossover at 250hz...is this normal?...my center is at 60 and my sub at 150...then it says mains are full range?...whaaa?
    My SETUP
    AVR: Denon 1913
    Main L/R: Polk LS90's
    Center: Polk CS350LS
    Side Surrounds: Polk LS/FX's
    Rear Surrounds: Polk RT/FX's
    Subwoofer: Polk PSW300
    100% Cinematic Adventures, 0% Music
  • rpf65
    rpf65 Posts: 2,127
    edited March 2013
    Don't know what you have, but rerun cal program. Sometime there is a glitch, or some other sound the mic picked up. Check your wiring, and the jumper on the back of those speakers, if it has one.
    edited March 2013
    ScottyDugs wrote: »
    Would help if we knew the speakers your using.
    As far as the auto calibration goes, the mic needs to be in your listening position at ear level. Also the house needs to be dead quiet as any other noises going on will throw the whole thing out of whack.
    Try setting speakers to small and crossover at 80 for a good starting point if you don't want to fly with what it is at now.
  • ScottyDugs
    edited March 2013
    avr: Denon 1913
    center: polk CS350LS
    mains F/L: polk LS90
    sub: polk psw300
    surrounds: LS/FX
    My SETUP
    AVR: Denon 1913
  • KLapinas
    KLapinas Posts: 608
    edited March 2013
    I think 50 or 60hz is best IMHO.
  • ScottyDugs
    edited March 2013
    KLapinas wrote: »
    for which speakers? the surrounds?
    My SETUP
    AVR: Denon 1913
  • oleon621
    oleon621 Posts: 178
    edited March 2013
    80-120hz is good for the surrounds. You could do 60-80hz for your mains and I would go 80hz for your center. Or as others suggested keep it simple and go 80hz all the way around. I have my mains at 60hz and everything else at 80hz.
    Front- RTI A7,(powered by ADCOM GFA 5500)
    Center- CSI5,
    Surrounds- RTI 6 and Rear Surrounds- TS 15.
    TV-Panasonic P55ST50
    SUB-SVS PB10-NSD and PSW505
    Receiver- Yamaha Aventage RX-A2000
