difference between xfmr designs ?
leftwinger57
I 've seen these 2 types of power transformers and wanted to know if there is a performance difference besides the obvious design feature. The round Toroidal that is found in more modern solid state amplifiers and the box type audio amplifier transformer used more predominately in older tubed or earlier ss amplifiers. I know transformers are all about the windings and how that is done and how many in what direction and so forth.Does either dissapate heat differently, is it a weight issue? So for engineering 101 what is the practical difference between the 2 styles of transformers.
Toroids are more efficient and have lower radiated noiseHome Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
As well typically toroids can be up to half the size and weight of an equal VA rated conventional EI core.
