Little home theater speaker sizing question.
Nattles
edited March 2013 in Speakers
I am planning on building a 7.1 home theater using RC 65i for the front and back speakers, RC 60i's for the middle speakers, TL2 center, and either the PSW110 or the 505. My question has to do with Size of the speakers. I do not want to spend money on the larger 8in speakers if they are not needed. The room is 15 by 20. Any insight would be greatly appreciated. I am thinking about powering them with Onkyo txnr616 or 515. Also do I need to insulate the hollow wall bays?
  • Nattles
    edited March 2013
    Thank you I like the overall size of the PSW 110 but it seems under powered. I will look at the Phantom center too. I am not familiar with the term.
  • goofyGAguy
    edited March 2013
    Nattles wrote: »
    LOL, it's not an actual speaker. It just means sending the center channel info to the left and right fronts.
    My humble setup...
    ...is no more. :cry:
  • leela222
    edited March 2013
    Our family room is about 10 x 12 and I love our TL2 center. I can't stand a huge center speaker. I just had to tweak my settings a bit. I know you guys are audiophiles but our little room rocks! I have Sony towers for my L/R which will be changed eventually to some Polk towers and TL2s for my side surrounds. The rears are small Sony HTIB speakers which will be changed to another set of TL2s.
    My H/T:
    AVR: Pioneer VSX-921-K
    Front L/R: Sony Towers SS-MF600H (will be upgraded to M70's or 75T's)
    Center: Polk TL2
    Surrounds: Polk TL2
    Rear Surrounds: Sony satellites from old HTIB (will be upgraded to TL2)
    Subwoofer: Sony from old HTIB (will be upgraded to DSWPRO550wi)
  • Nattles
    edited March 2013
    goofyGAguy wrote: »
    I really wish I could say that I meant look into the Idea.:redface: But I found a C15 for a great price on Newegg. Now to find the other speakers.
    I noticed goofyGAguy you have a PSW110. I am trying to decide between 505 and 110. How do you like the sub?
  • goofyGAguy
    edited March 2013
    Nattles wrote: »
    Well, you should take my opinion with a grain of salt, since the only sub I've ever owned besides the PSW110 was the sub that is part of Polk's RM6750 5.1 package (which is a great package for the money they can be found for these days, btw). So, I don't have much to compare it to. Having said that, I bought mine for $125 at the big blue & yellow place brand new, and for the money I paid I'm quite happy with it. Will it knock pictures off the wall? No way, but it's not made for that. In your size room though, I would vote for the 505, especially if most of your use will be movies and not music. Hope that helps.
    My humble setup...
