Lack of power?
38Fountain
I have an Alpine head unit CDA9886M with 6 pre outs, using the one marked SW into a Polk PA D4000.4 bridged into 2 Polk MM1040 subs they are not very loud, I checked the polarity on the subs and tried every setting but, you can stand right next to them and talk to the person next to you...... any thoughts? at 400 watts to each bridged they sound way under powered.
Post edited by 38Fountain on
400 watts isn't that much. I think you're expecting too much. That'll be enough for good solid bass but it will NOT be enough to drown out your conversation.
But yeah, check your settings to make sure you're playing the right frequencies thru them.polkaudio sound quality competitor since 2005
Settings: Stereo, switch on BPF, LPF switch out, LPF knob about 100hz, level between 3v and 200mv. Head unit: sub level and bass level at max. I cant say there is even a solid thud, more of a rumble. I have a 400 watt audiobahn with a single 12 that sounds 10 times as loud and more solid hooked to a factory radio.
I know you said you checked it, but try reversing the polarity on one of the subs and see what happens.
If that happens, you did something drastically wrong...haha
I just hooked up an AudioBahn A4002T rated at 100 watts per channel, it's only a 2 channel amp. It sounds
WAAAAAAAY louder and clearer. While I'm not arrogant enough to think I'm beyond making a mistake, I've been a Honda technician for 21 years, my specialty is electrical. I've tried 2 of these PAD4000.4 amps with the same result.... pulling out what little hair I have left. -
WOOHOO...... IT WORKS!
the problem was the instructions, or should I say, the lack of instructions. While the instructions do show you what is printed right on the amp, it does not elaborate on any of the settings when connecting 2 bridged subs. As per the instructions, used FRONT inputs,set to stereo, BPF, adjusted levels...... only on the FRONT side, NOWHERE does it tell you to set the adjustments for REAR. A little less information on the obvious and, a little more on the details would be a better manual
