Legit Hdmi sources
K-daugh
Does anyone know of any legit Audioquest dealers on fleabay ? Also what other brands are of top notch quality . Similar to the Carbon range ?
Budget 5.1 H.T. Set Up
HK avr 247 - Adcom GFA-7605
Mirage Bps 150i powered sub - 40"Samsung LCD ln40c530 - Sony Blu Ray Player BDP-S370 - Comcast digital hd box(motorola dcx3400)
Monoprice Premium Interconnects Monoprice Ultra Slim HDMI w/Redmere
Custom Jumpers
Post edited by K-daugh on
Not on ebay, but crutchfield sells them
Audioquest says that no one who sells their current line of products on eBay is an authorized dealer. Check the upper right corner of their main page to see the full explanation.
Asking which brand of cable to use is like asking what motor oil you should put in your car. You will get 7890710987 answers and all of them will be right and wrong depending on who you ask. Only your own ears are going to tell you who was which.
I was thinking build quality. Which brands are built extremely well ...which brands are built the BEST!!Budget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605- Belkin PF60 Power Conditioner - Cs2 center channel - Monitor 60's fronts - Monitor 30's rears
Monoprice Premium Interconnects Monoprice Ultra Slim HDMI w/Redmere-Knukonceptz Kord 10 Gauge Speaker Wire - Nakamichi Banana Plugs
Custom Jumpers -
Good deals on amazon for all AQ cables
The best built would have to be the wireworld silver star light series and above, they are some of the most expensive choices -
likes wearing fishnets...^^^^HT SYSTEM-
lsi 9's -
Nah man, sorry PFB that wasn't directed at you. Last night we had a spammer posting in a bunch of threads so I replied with my own remarks. Then they all were deleted leaving me looking like an a-hole to the previous poster. Oh well, it was fun at the moment.HT SYSTEM-
