dipole or bipole?
warviper
warviper Posts: 585
edited December 2003 in Speakers
just wondering whats the superior opton for surrounds?
Wish I was a polkologist then I could call my self Dr.warviper.
Post edited by warviper on
  • danger boy
    danger boy Posts: 15,722
    really whichever one sounds better for your particular needs.... both sound good.. the only difference between the two is where you have your surrounds place and how the sound pattern comes from those surrounds. ..
    if they are on a wall behing you.. facing foward.. use bipole
    if they are on the side of you. use dipole.
    but this is only what's recommended.. play with both settings... and play with both locations.. whichever one you like is the correct setting and location..
    i run mine bipole. it's what sounds best to me in my particular setup.
    PolkFest 2012, who's going>?
