Looking for a new pre pro. Suggestions
del44
My Rotel RSP-1068 has served me well for many years, but it's time to get another pre that has HDMI. It's getting to be a pita swapping out HDMI cables between my dvd player, blu-ray, front projector, plasma tv. Looking to spend around $1000, new or used. 2 channel is not a priority as far a sound quality, I have a Musical Fidelity A5 preamp for that. Auto calibration would be nice. I really need to be able to switch between 2 HDMI outputs. One for the TV and another for the FP. Thanks.
Post edited by del44 on
Accessoriess4less has a nice Marantz pre-pro (AV7005) that would fit that bill.
Factory refurb, 2 HDMI outs, Audyssey XT, balanced and unbalanced out, 7.2 capable, Zone 2 & Zone 3 pre-outs. ONLY downfall is its only got 4 HDMI inputs... but you could in theory get a HDMI switcher that is remote control capable and if you have a universal remote it wouldnt be too big a deal."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Not many players in the pre/pro w/ HDMI game, even less with 2 HDMI outputs. In fact the Marantz is the only one I can think of that has 2 HDMI outputs. If there are others, I'm not aware of them.
I would think if you have a programmable remote, Ender's suggestion of an HDMI switcher would be the way to go, rather than being forced into a particular pre/pro. Not that the Marantz is bad, but neither is the Rotel you already have.
Something like this:
http://www.monoprice.com/products/product.asp?c_id=101&cp_id=10110&cs_id=1011002&p_id=6415&seq=1&format=1#largeimage
Monster AVL-300, HTS-2500 MKII -
I would look at the Oppo BDP-105...
That thing is no regular Blu-Ray player, it's a full on Pre-Pro replacement. Two HDMI outputs and two HDMI inputs (one is even MHL compatable), digital audio inputs, 7.1 analog out and dedicated 2ch out (RCA and Balanced).
http://oppodigital.com/blu-ray-bdp-105/
When my Denon kicks the bucket, I will be picking that bad boy up. -
Check out the Onkyo PR-SC5509, I believe it also has 2HDMI outs. The 5508 I have does.Home Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
Its outside his range or I woulda mentioned it. IIRC ~1400"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Got mine for 1495 at accsecories4lessHome Theater
Two Channel
Upstatemax wrote: »I would look at the Oppo BDP-105...
Not to mention..........it sounds SWEET!Frank
Polk LSiM 703 mains on Skylan Stands
Polk LSiM 704c center
Polk FX500i surrounds
Parasound 5250 Amp
Oppo BDP-105
SVS PC Ultra tuned to 16hz
Panasonic 65" Viera Plasma -
Denon Frank wrote: »Not to mention..........it sounds SWEET!
Are you using your 105 as a pre? -
Thanks for the input. I like the Marantz and if it's built anything like the DV-9600 that I have, that's even better. I was toying with the idea of the HDMI switcher but I think I'm ready for a change and simplicity that a newer prepro can offer. The Onkyo is slightly out of my price range but who knows. I noticed that the Marantz has 2 sub outs. Does that mean that they can be adjusted seperately? That would be nice. I don't think I will go the Oppo route.
+1 for the Marantz AV7005. Lots of features, reliable, has passive HDMI switching, and bottomline sounds fantastic
Just because I'm looking at this unit for myself in the future:
Why are you passing on the Oppo? -
I had an Oppo universal player a few years ago, forgot what number. It wouldn't work with my system. DVD-A and SACD in multichannel was fine but 2 channel SACD listening through my Musical Fidelity preamp had distortion. I was able to return it for a full refund. Oppo tech said that the Oppo wasn't suited for my particular system configuration. Something lik 2 channel outputs were in parallel with front l and front r multi output. I have since got another universal player (Marantz DV-9600)that I plan to keep. But like I said, it did perform good in 5.1. The Oppo BDP-105 looks like a nice player but I already have a bluray player. I also need 12 volt triggers to turn on amps and power centers. I need at least 3 opt inputs and 3 or more hdmi inputs.
+1 to marantz. Oppo 105 is also a great one to consider.
I think the one thing that the Oppo needs to be a real game changer is Audyssey.
Go for a Anthem pre pro as ARC is awesome
