DLP vs Plasma vs LCD
brentman0110
brentman0110 Posts: 87
edited February 2007 in Electronics
So, Is DLP really the best? Size not being a consideration.
Post edited by brentman0110 on
  • Fireman99
    Fireman99 Posts: 129
    edited December 2003
    Dont know if it is the best or not depends on what you like in the picture. It is at the top of my list of new TV's to purchase. Considering a Front projection as well. Just started to look into the front projector though.
    Dan
    Recever AVR 8000
    Amp PA 4000
    CDR 26
    Mains RTI 150 Bi wired
    Center CSI 40 Bi wired
    Surround FXI 30
    Rear RTI 4
    Sub PSW 140
  • brentman0110
    I do not care about size but I do not have the room for a front projection. I want crystal clear PQ for movies. I am considering the Samsung 61" Widescreen DLP HDTV Monitor.
  • ChrisDurano
    ChrisDurano Posts: 372
    what's your price range?
    Home Speakers polkaudio RTi70's (bi-wired), CSi30, FX3000i, PSW250
    Car speakers polkaudio EX 369, DB 650
  • PolkThug
    PolkThug Posts: 7,532
    Samsung was first to market on these, and kudos for that, but I think there is still a lot a growing room for PQ. DLP viewing angles kind of well, suck. The coolest thing about the DLP, is that you can pick the TV up over your head.
    In the LCD realm I think the Sony XBR 60" LCD is really good (It's the only Sony product I would buy). However, the Hitachi S series (non-LCD) have the best picture quality. Hitachi also has an X series which is their flagship, but they don't seem to be carried in big chain stores, at least not around here.
    Regards,
    PolkThug
  • thehalo8
    thehalo8 Posts: 127
    Keep your eye out for TV's coming out with LCOS chips in them. These are the chips used in all the high end external front projection systems. They will have three of them in the tv's like the three LCD's in the Sony tv's.
    Mains: Polk RTi70's
    Center: Polk CSi40
    Surrounds: Polk TC60i's
    Sub: Polk PSW505
    Receiver: Onkyo TX-DS696
    TV: Samsung HLS 5687W 56"
    DVD: Sony DVP S5300
    Protection: Monster HTS 3600
    Backup Battery: Belkin AP3080010
  • goingganzo
    goingganzo Posts: 2,793
    actuley the samsung dlp 61 is very hard to find in stock it is very hot. and yes it has the best pq of all and none of the drawbacks of the others. but it is not 4 in thick.the dlp is beter than the plasma and still sas the ability to improve alot. the samsung has the mustang 2 chipset in it and the new + chipset just hit sema last spring. also they can do a 3 pannel dlp like the lcd but that is costing a mint right now.
  • thehalo8
    thehalo8 Posts: 127
    Yeah I don’t understand that one. Why does it not cost that much for three LCD chips, but it cost so much for three DLP chips? I know they work on different technology, but why such a big difference in price?
    Mains: Polk RTi70's
    Center: Polk CSi40
    Sub: Polk PSW505
    DVD: Sony DVP S5300
  • PhantomOG
    PhantomOG Posts: 2,409
    the cost of the DLP chips will be considerably higher because it is MUCH more complicated to make.
    the LCD chips are just standard semiconductor chips, while the DLP chips are MEMS devices (micro-electromechanical systems), which is still a young technology and more expensive to produce.
    the chips for LCD panels are less complicated to produce than state of the art microprocessors, and can leverage the advances in fabrication made from microprocessors. flash memory, embedded chips, etc, and LCD chip can be produced on technology that is a few years old and has been mastered and made cheap.
    on each DLP chip, which is probably smaller than the size of a quarter, there are thousands of micro-mirrors which actually move to redirect light. this is much more complicated to fabricate than standard semiconductor chips with no moving parts. this more complicated processing causes yields to be much lower, which increases the cost per die (chip).
  • brentman0110
    I went to CC today and looked at the Samsung line of DLP's and the Sony XBR 60". For the price, the XBR seems to be a better deal. But, If you have to replace the bulb on the Samsung every couple of years at $200-$400 a pop...I dont know. The PQ is very comparable. The 60" XBR was going for about $4,000 and the samsung 61 for about $5,000. I also looked at the Hitachi Ultravision, it goes for about $3,500. It looks good except from the side. Any opinions?
  • brentman0110
    I went to CC today and looked at the Samsung line of DLP's and the Sony Grand WEGA XBR 60". For the price, the XBR seems to be a better deal. Especially, If you have to replace the bulb on the Samsung every couple of years at $200-$400 a pop...I dont know. How often would the Grand WEGA need repair or replacing? The PQ is very comparable. The 60" XBR was going for about $4,000 and the samsung 61 for about $5,000. I also looked at the Hitachi Ultravision, it goes for about $3,500. It looks good except from the side. Any opinions?
  • brentman0110
    Sorry, The XBR GRAND WEGA was going for 5,500.
  • fireshoes
    fireshoes Posts: 3,167
    I prefer the Hitachi to the Grand Wega hands down, but I prefer the Samsung DLP's to any LCD or plasma. Stuck pixels drive me crazy! They say the next generation of DLPs will be even better, as they've figured out a way to improve the contrast ratio.
  • PolkThug
    Since you've got room, go with the Hitachi S series or higher, and take all that money you saved and order an SVS Subwoofer. As for viewing angle, Hitachi has the best for traditional rptv. and besides, who is gonna sit way off to the side of any tv and try to watch it? ;)
    Regards,
    PolkThug
  • goingganzo
    next gen on dlp is a 6 or 7 segment color weel with the mustang 2+ chipset last year was the mustang 1 and this years tec is the mustang 2 with comes in all rp dlp that samsung sells.
    runco front projector with the mustang 2 sells for about 9k if you get the 3 chip dlp it sells for 30+k i am prety sure on thoes priceses.
    with res going up and new technology comeing out. there is this new screen that will make plasma junk. it is thin as a piece of paper but it is ilny in color and the res is not to high.
  • walk
    walk Posts: 178
    RP CRT is still the way to go, unless you have the BIG bucks.
    You can get a 47" 1080i capable RP-CRT HDTV for less than $1500 now.
    Plasmas are great but expensive and still only do 720p. Unless maybe you drop $20,000 for the 61" - I wouldn't know...
    RP LCD - too expensive for what you get. Twice the price of the same sized RP CRT's and the picture isn't that much better, or any better at all, that I could tell.
    Direct-view LCD - small, overpriced, horrible view angles, blurry motion artifacts (too slow refesh).. need I say more?
    RP DLP - overpriced, picture isn't that much better than CRT or LCD, plus it makes me seasick to look at it. I guess I'm one of the "sensitive" ones. Maybe once they work out the issues. But by then they will be doing 1080i capable plasmas (1800x1024) so it will be moot. IMO DLP is dead in the water.
    - Sony 50"A3000 SXRD; Onkyo TX-SR 805
    - Polk RTi150 mains; CSi30 center; FXi3 surrounds, R15 backs
    - Velodyne CHT-12 subwoofer
  • brentman0110
    What about the Sony XBY Grand WEGA? I was looking at the 60" for about 5,000. It is a rear projection LCD.
  • kberg
    kberg Posts: 974
    walk, what make is this and where can it be bought?
    Mains: polkaudio RTi70's (bi-wired)
    Center: polkaudio CSi40 (bi-wired)
    Surrounds: polkaudio FXi30's
    Rear Center: polkaudio CSi30
    Sub: SVS 20-39 PC+
    Receiver: ONKYO TX-SR600
    Display: JVC HD-56G786
    DVD Player: SONY DVP-CX985V
    DVD Player: OPPO DV-981HD 1080p High Definition Up-Converting Universal DVD Player with HDMI
    Remote: Logitech Harmony H688
  • JimBRICK
    JimBRICK Posts: 1,543
    I'm still waiting to see the dlp's with the LED light,
    the best picture I';ve seen with this years line up of tv's is the
    KDS60A2000
    KDSR60XBR2
    thats with my own eyes, but still when the led's come out they're going to slap these tv's around
    2 CHANNEL
    Speaker - Klipsch Heresy II
    Under construction
  • Sherardp
    Sherardp Posts: 8,038
    I have a 61 inch Sony LCD and 61 inch Panny DLP, the DLP has a slight edge over the sony, either way you cant go wrong though.
  • steveinaz
    steveinaz Posts: 19,545
    Samsungs latest bulbs run around $198 from samsungparts.com. I just bought a Sammy 50" DLP (HL-S5086W), here's what I've found:
    Pro:
    DVD's are spectacular, literally (after calibration with DVE)
    Light weight, my 50" is 62lbs
    Fairly narrow in depth, about 14"
    I'm able to make standard def TV look really good with some tinkering
    Excellent contrast/color
    Screen has virtually no reflection
    Tons of inputs
    Cons:
    You won't get BLACK blacks, but close
    TV speakers/audio is pitiful/extremely generic
    Mine was $1344.00 from Sears. My cable company doesn't have Hi-Def yet down here, so I can't comment---but if it looks anything like the DVD playback, I'll be doing back-flips. FWIW, if plasmas weren't so expensive, I probably would have went that route--but the cost difference doesn't justify for me.
  • Ferres
    Ferres Posts: 310
    Another plus is that rear projection is the most energy efficient of the large screen format TV's.
    Gear: Rotel RC 1082, Rotel RSP 1068 pre/pro, Rotel RMB1077 amp, Cayin CDT 15a CD player, S301 bluray.
    Speakers: Tannoy DC sensys speakers, Paradigm Servo15 Sub, Velo Spl-1500r
    Conditioner: Isotek :D
  • Sherardp
    PLus no burn in issues with LCD or DLP, although plasma still reportedly delivers the best PQ. Go DLP and forget about, Panny or Sammy and some Mitsubishi models are the preferred.
  • maingey
    maingey Posts: 632
    KDS60A2000
    KDSR60XBR2
    Samsung's is already out but only in 56". Has already been review by Sound and Vision, (I Think) about 2 months ago... Pretty decent ratings. Still think Plasmas are best, but I work with mostly Fujitsus and Runco's. We are authorized dealers for all kinds of brands, but you see them in the shop everywhere around us, so we go for the names you typically don't see. The new Runco 50" is a 720p panel, with 1080 colour processor. We've had folks come through our store thinking '1080p' and saying it looked just as good if not better than Pioneer's 1080p plasma. Then I tell them the price tag, and they get turned off. It's actually next to a Toshiba 1080p 47" cinema regza, and it makes it look bad, but in all honesty the Toshia on it's own looks decent. Just qc issues. (and the HDDVD player hooked up directly to it doesn't hurt either.
    Whoever mentioned Hitachi Director series (HDX) is right on the ball. In standard consumer lines I think it's prob the better plasma sub $5000. Just hard to find.... I think DLP are ok, haven't seen the LED unit. I don't like how the standard units make a picture but pretty promising. Aim high, save pennies, get a 'better brand'.
    My chump change.
  • Disc Jockey
    Disc Jockey Posts: 1,013
    Just be careful and don't hurt yourself because you will be doing back-flips when you get HD, it looks that good. Nothing available for you ota?
    "The secret of happiness is freedom. The secret of freedom is courage." Thucydides
  • steveinaz
    No, small desert town--too far from Tucson...
