Onix Rocket RS850 Signature & RSC 200 Bigfoot Speakers
ecod123
A pair of Onix Rockets RS850 Signature Edition floorstanding speakers and one Rocket RSC 200 Bigfoot center, in beautiful Rosewood and shining piano black top and bottom. Well-regarded speakers which are fantastic for both music listening and HT. Great sounding and great eye candy factor, garnering praises from non-audiophile guests about the gorgeous look.
In excellent condition except for a couple of light scuff lines on the side of one of the 850 Sigs. These are faint lines and visible only when viewed very close. There is also a small 2mm nick on the back edge of one of the speakers. All these marks are not clearly visible unless at very close but I am a little OCD :cheesygrin: so thought I point them out. I included pics to try to show them. Other than that, excellent condition overall.
Unfortunately, I do not have the shipping boxes so am looking for a local sale first. Location: So Cal. (Los Angeles)
Rocket 850 Signature pair - $850
RSC 200 Bigfoot -$275
850Sig backs and Bigfoot front
850Sig fronts with grilles off
850Sig with grilles on
Side views showing beautiful grains on veneer
2mm nick on the edge (halfway down)
The faint lines are in the reflective area showing no deep scratches
Post edited by ecod123 on
Price reduced for a sweeter deal.
Rockets 850 Signature pair - $795
RSC200 Bigfoot -$225 -
Thanks. This 850 Signature pair with the Bigfoot would make a great front 3 HT set.
The 4 metal 5.25" woofers and a 4" midrange, coupled with the well regarded Vifa Tweeter make for fast responsive speakers. Smooth high and midrange plus an impactful bass. Wish I have the shipping boxes because I already have out-of-state interests but since these are heavy (which is good for floorstanders), would be costly to have them professionally packed.
Specs:
• System: Modified Three-way, Vented Enclosure
• Drivers:
One 1" Vifa Ring Radiator
Tweeter, One 4" Aluminum Midrange,
Four 5.25" Aluminum Woofers
• Crossover: 1.5 kHz, 6 kHz
• MFR: 36 Hz to 20 KHz (± 3 dB)
• Impedance: 6 Ohms Nominal
• Efficiency: 90.5dB @ 1 watt / 1 meter)
• Dimensions: 45.5" H x 11.8" W x 15.6" DIf you weren't in So Cal, I would be knocking on your door tonight. Have a friend in Denver that has a full 7.2 setup using these as his mains *and* surrounds with the same center and it's amazing. He is REALLY into blu-ray concerts and you truly do feel like you are at the venue with that setup.
GLWS. -
You got PM.
