Amp help needed.
Systems
Im almost 16 years old and the car i decided to buy for my first car is a 1996 ford escort. nothing very special, but its not a bad car. and from the ones ive heard, systems sound pretty good in escorts. but the problem is i recently bought two polk dx series 12 inch subs for it. i made my own dual bandpass box. for the 5.25 inch front speakers im using eclipse which in my opinion is a good brand. for my back speakers im using 5 X 7 inch eclipse speakers. And i have an alpine deck. So i have it all ready except im not sure about the amp. ive looked at many different ones but i cant quite figure out which one i should use. I was thinking about either a 1600 watt power acoustik or a 1600 watt pyle audio amp. None of my friends or myself have ever heard of pyle audio so im not sure if its a good brand at all. its much cheaper so id like to use a pyle one if it will sound good. so can anyone tell me how good pyle is? or possibly reccomend another amp to run these two subs????
Testing
Testing
Testing
Testing
Testing
find a link to the exact sub you have, post it on here, and we can help ya out
pyle is a pyle of ****
-Cody -
this was actually a post i made this morning.. i made a new one ezier to understand so thanks for the help . Oh but what is ur opinion of the eclipse speakers?-Matt
but what about a poser acoustik.. are they a descent brand? If so which amp model would you recomend? this is my sub though: http://www.polkaudio.com/car/specs.php?name=dx12-4-Matt
well never mind.. this post is over i made another post and got all the help i needed so you can look at this post.. but if you reply to it i probably wont check it out cuz my problem was solved.
Matt-Matt
