Nice Classic Harmann Kardon HK 670 60 watt /ch AM/FM receiver 1979
geppy1
geppy1 Posts: 3,076
edited March 2013 in For Sale (FS) Classifieds
My last HK 670 for sale. Very nice Harman Hardon HK 670 AM/FM receiver from 1979. Probably one of the 3 best receivers they ever made. This one has been serviced with DC and Bias checked and set and any soilder joints that were borderline have been reflowed This features 60 watts per channel of high current and has not problem driving low impedence loads. The sound quality is excellent . Nice phono section. The A terminals have been updated for use with bananas but the originals will be included. The original power cord as been repaired as I use a detachable with my gear. The receiver is very clean There are a few scratches on the top side of the faceplate but the but overall very sharp looking . This unit needs nothing and works as it should Asking $175 Thanks,
60 watts watts min. RMS per ch, both driven @ 8 ohms
Power Bandwidth: 8Hz-100kHz @ < 0.08% THD @ 8 ohms both channels driven simultaneously
Total Harmonic Distortion: 0.03% 1kHz at rated output
Intermodulation Distortion: 0.05% at rated output
Frequency Response: Below 3Hz - 140kHz -3.0dB FM - 20Hz to 15kHz +/-0.5dB
Damping Factor: > 30 at 8 ohms
Hum and Noise: PHONO - -90dB "A" weighted, IHF
Aux & Res - -102dB "A" weighted, IHF
Slew Rate: 65V/usec
Rise Time: SQUARE WAVE - 2.5usec at 20kHz
Square Wave Tilt: <2% at 20Hz
Negative Feedback: 28dB
Sensitivity: PHONO - 2.2mV HIGH LEVEL - 130mV
Phono Overload: >225 mV
Input Impedance: PHONO - 47k ohms
Usable Sensitivity: FM MONO - 1.9uV
Quieting Sensitivity: MONO - 3.0uV STEREO - 30uV
Signal-to-Noise Ratio: FM - -75dB Capture Ratio: 1.2dB
Alternate Channel Selectivity: -75dB Image Rejection: -80dB
IF Rejection: -110dB
AM Rejection: -62dB
Stereo Separation: 55dB at 1kHz
Distortion: FM MONO - 0.05% at 1kHz, 100% modulation
FM STEREO - 0.08% at 1kHz, 100% modulation
AM Section Sensitivity: 300uV/meter Selectivity: -40dB Alternate
Channel Selectivity: -35dB
Image Rejection: -50dB at 1kHz
IF Rejection: -45dB at 1kHz
Dimensions: 440 (17.32 wide) x 163 (6.5 high) x 398mm (15.6 deep)
Weight: 30 lbs
Post edited by geppy1 on
  • dromunds
    dromunds Posts: 10,100
    edited March 2013
    edited March 2013
    Nice piece! Man what are you? A vintage audio "warehouse"? So many, many, many pieces come and go!
    cnh
  • geppy1
    geppy1 Posts: 3,076
    edited March 2013
    Why thank you. No really I sold off my high end stuff 2 years ago to pay the bills and it has been going downhill since. I am trying to find things (sound) I can live with. It is hard to go backwards. I bring things in, compare them to the previous winner and then i must move the loser of the head to head out the door. I cannot even afford to keep two items. Then it never fails once I sort of settle on something another $$ problem comes up (car issue medical bill ) and we start over again. Welcome to the USA in 2013
    SOLD
