Any favorites for a rectifier tube?
madmax
madmax Posts: 12,434
edited March 2013 in 2 Channel Audio
I'm replacing some 5ar4 and 5u4 tubes, any favorites? Currently using sovtecs.
Vinyl, the final frontier...
Post edited by madmax on
    SCompRacer Posts: 9,112
    edited March 2013
    IMO Holland made (Phillips) with double D getters are the best GZ34/5AR4. Either metal base (uber pricey) or Black base with metal base innards. My Holland made Black base with metal base innards are branded Mullard. GB manufactured Mullard are fine too.
    Some I have used. Except the Ruby on right that was sent with a power supply upgrade; I just kept it for a spare. I had some linkage to 5AR4 history at home, have to check later and post them if still there/active.
  • organ
    organ Posts: 4,969
    edited March 2013
    I used to own a few amps with 5AR4 rec tubes. IMO, if you can't find or don't want to spend a fortune on Mullard, the Sovtek is probably the next best thing. After using the Mullard, I used Sovtek for a few years.
    What type of 5U4 do you use? They have a standard, G, and GB. I've read very good things on the Shuguang 274B. Suppose to work as substitute on most units using 5U4 but you usually have to check with the manufacturer http://www.thetubestore.com/Tubes/5U4-Tube-Types/Preferred-Series-274B-5U4G . Stay away from the =C=. They're leftover military stock and some are known to arc under normal operating specs. I read about it on Audio Asylum and it happened to mine as well.
  • madmax
    edited March 2013
    "metal base (uber pricey)"
    I would call the pair of 5ar4s I found somewhat pricey... $1500!!! Thats way out of budget although I don't plan to be cheap.
    Right now I have the standard 5u4 sovtecs. One of them sparkles on top when I first power up.
    edited March 2013
    madmax wrote: »
    They were in the few hundred dollar range so when I was looking a few years back. After doing some research I just got the black base instead.
    I recall ModWright had some issues like that with a batch of new Sovteks so he started using the Ruby's. I had a Sovtek that did that; a blown power supply fuse usually followed.
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited March 2013
    I have an RCA tube that I bought from Brock with the norh and its very good, much better than the stock tube
  • AsSiMiLaTeD
    edited March 2013
    To clarify, the tube I am using appears to be the third from left in the first photo above
    edited March 2013
    It could be that one, or one of the two he got, IIRC.
  • AsSiMiLaTeD
    edited March 2013
    SCompRacer wrote: »
    I'm not following you?
  • madmax
    edited March 2013
    So why would a 5ar4 tube bring such a high dollar value, that one pair was as much as some really good nos 300Bs. I saw several pairs in the 100 to 400 range, that is where I'm looking. I need 4 of the 5u4 so I'm looking to spend less on them. Manley says they design their equipment to work best the cheaper production tubes and changing to more expensive nos tubes is not required, may even hurt the sound. However, I've found that every tube I replace with something really good has provided a noticeable improvement.
    edited March 2013
    Tuberaider :cheesygrin: raided my stash one day...pretty sure he got a pair of those from me. ;)
    edited March 2013
    madmax wrote: »
    So why would a 5ar4 tube bring such a high dollar value...
    Scarce....kewl looking, desireable....hype if you don't believe? Bendix 6900 tubes are another example of where I took the low road. MU Engineering bought Bendix Red Bank Division. They rebranded old stock and continued to manufacture on Bendix tooling. $800 for Bendix 6900 or $200 for MU6900. Had both, sounded the same, sold the Bendix. Now MU pulls higher prices.
    heiney9 Posts: 25,447
    edited March 2013
    madmax wrote: »
    Hands down Holland made GZ34/5AR4. Not cheap but awesome sounding and will last forever. As Rich said the metal base version is the one most coveted and you've seen the price already. Any mid 60's Holland made GZ34 is far better (IMHO) than the Sovteks. I've run both and the difference was very real.
    Here's a primer on what to look for. Other branded tubes are a bit cheaper than one that has a Mullard label on it.
    http://www.tube-classics.de/TC/Tubes/Valvo%20GZ34/GZ34.htm
    edited March 2013
    SCompRacer wrote: »
    Yep and I still have 2 left and they probably aren't going anywhere anytime soon. I couldn't sell Assimilated the Norh amp w/o a great rectifier to go with it, that would have been a huge disservice. :cheesygrin:
    edited March 2013
    madmax wrote: »
    Pure marketing bunk as NOS tubes are too scarce for manufacturers to use them as original tubes, so to "save face" they try and represent current cheaper tubes as being just fine. When in fact you and I know that's not really the case.
    edited March 2013
    Here is another site for tubes, 5AR4/GZ34 on this page.
    http://natubes.com/index.php?page=product&do=browse&catid=108&parentid=61
  • larry777
    larry777 Posts: 480
    edited March 2013
    Their is a Phillips MiniWatt made in Holland GZ34 tube NOS on Canada's Canuck Audio Mart for $139 with clean white print. Also a GE Blackburn Mullard for $100. Not sure if these are good prices but thought I would mention it anyway. They are supposed to be new tubes.
    Home Theatre.............
    Pioneer SC-35
    Polk RTi10's Fronts
    Polk CSiA6 Center
    RTi4 Surrounds
    SVS PB-12 Sub
    2 Channel.............................
    Yaqin MC-100B
    Energy RC-70 Speakers
    Arcam CD-192 Disc Player
    Van Den Hul Interconnects
  • cc43fan
    cc43fan Posts: 22
    edited March 2013
    +1 on the Mullard
