TL3 Blackstone speakers with Bose UTS and UFS
chen
chen Posts: 5
edited February 2013 in DIY, Mods & Tweaks
I'll admit this is probably not the smartest move but anyone got the Bose UTS20 and Bose UFS20 mounted for your TL1 or TL2 or TL3 Blackstone speakers?
Does it fit? I think the speaker stands will be ok... will the table stands be okay?
I'm hoping it does but I'm thinking it doesn't... The TL3 speakers are pretty big... The reason I got the bose ones was because it was on sale and it seemed heavy and you've got to admit it's got good design (i don't know about usage effectiveness).
Anyway, if it doesn't work out, what do you recommend that's relatively cheap? As in, what stands do you have that you find awesome, heavy, good looking aesthetically and works with wires (14gauge)?
Moved post to here because it might be better.
