rt25i tweeter model #?
nhhiep
nhhiep Posts: 877
edited February 2013 in Vintage Speakers
does anyone know the model # of the tweeters in the RT25i? SL6501 ?
I found a set on CL and need to replace the tweeter in my SRT.
Post edited by nhhiep on
  • Tbone289
    Tbone289 Posts: 661
    It's a shame that some of Polk's schematics show the model number, and others (like the RT25i) don't. I will try to remember to pull one out of mine during my lunch break today to check the number for you. I don't believe it's the SL6501 though--that was used in the earlier models such as the RT7.
    2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0
  • Mystery
    Mystery Posts: 2,546
    From old threads...
    Original tweeter on RT25i is part number BD0125-W and has been replaced by part number RD6514-3.
    The replacement is a silk dome tweeter.
    SRT uses either SL6501 or SL6500 tweeter so not sure what their actual part numbers are.
    Call Polk CS and they should know the part numbers.
  • nhhiep
    nhhiep Posts: 877
    thanks for the info. it's so hard to look for parts for SRT
  • Tbone289
    Tbone289 Posts: 661
    ugh... I'd hate to hear an RT25i with silk tweeters...
    nhhiep, I believe I might have an extra SL6501 at home. If you determine that's what you need, send me a message.
  • Mr. Bubbles
    Mr. Bubbles Posts: 736
    nhhiep wrote: »
    Yeah, i can imagine; it must really suck to own a model like that.:cheesygrin::razz::cheesygrin:
    In all seriousness though. Good luck, I know I've had a hard time finding a MW6511 for my 1C's, and passives to match SRS 2's, I can only imagine parts for the SRT.
  • nhhiep
    nhhiep Posts: 877
    Bought a pair of RT/FX on CL last night and lucky for me, they use the same SL6500. So now I have enough backup tweeters for my SRT. But it's still impossible to find replacement for the woofer (2 ohms MW5805 / 5807). Woofers in the RT/FX are MW5806 are 4 ohms, even though they look the same.
    Does anyone know what other speakers use MW5805/5807? RT3? M3 ?
