Cheap 7ft Speaker Cable Pair
zingo
I no longer need these speaker cables with my self-powered speakers, just they were good while they lasted. I made them from bulk 4x14AWG CL3 rated Monster cable with Parts Express gold bananas all around. They are currently set-up to bi-wire with two terminations at the amp end and four at the speaker end, but you could remove the second set of plugs if you want standard wire cables.
These cables are nothing fancy, but sound decent, work well, and are a nice upgrade from any zip-cord or hardware store wire.
$30 shipped CONUS for the pictured 7ft pair
Post edited by zingo on
Jake,
My bro-in-law needs to step up from cheap 18ga. If I buy these from you, would you reterminate the speaker ends to remove the bi-wire? -
Can do! You can even come pick them up and we can listen to some tunes!
Sounds like a plan. I'll take them.
