sub question....
ok. i decided to stick with the psw10 and just bought another one last night. It sounds freaking awesome. But do i need to go into setup and change anything? I already changed the original one to 80hz and the other touch ups you and other forums suggested......do i need to just leave the new one hooked up and it will pick up on the setup or do i need to go into the menu and do something for the new sub.....or easy as plug it in? thx.
Post edited by Legendary70 on
  • decal
    decal Posts: 3,205
    edited February 2013
    You shouldn't start a different thread everytime you want to add comments. It makes it difficult for other people who are involved/following your original post.
  • rpf65
    rpf65 Posts: 2,127
    Your AVR will recognize 2 or more subs as 1. Most AVRs with 2 sub outs split the single sub out signal internally, just as you would with a "Y" splitter. From what I've read, only the newest Audessy program will cal subs independantly, make individual adjustments, and then re-cal them for the rest of the speakers.
  • Legendary70
    Legendary70 Posts: 18
    ok thx. Also the sub from my onkyo 5400 htib i put in the other room with my sony 8500 amp along with some floor speakers it sounds great......my question is this though...the old onkyo sub which is also a 120watt like the new onkyo but is also about 5-7 years old. I want to plug it in in that same room along with the new onkyo sub....in other words i want to subs in that room?
    what do you all think? advice? thx.
  • rpf65
    rpf65 Posts: 2,127
    Check the impedance on that HTIB sub. A lot of them use things like 3 ohm speakers, and your AVR may hate them. As in running too hot, and possible smoking itself, the sub, and/or other speakers.
  • Legendary70
    Sorry. Im a newb. impedance on htib? 3 ohm? thx.
    txcoastal1 Posts: 13,518
    HTIB= Home Theater in a Box
    http://www.prestonelectronics.com/audio/Impedance.htm
    Speakers can operate different impedance....typical home speakers are 4ohm and 8ohm but there are 4-16ohm speakers and some will dip into less than a 2ohm load and your receiver/ amp must be capable to handle the load
  • Legendary70
    I appreciate the input.....but how do I know if my new and old onkyo subs are those numbers? thx.
  • rpf65
    rpf65 Posts: 2,127
    Should be a sticker/tag on the back of the speaker. The number followed by the spide down horse shoe is the impedance. If all the speakers were bought as a box set, they all match impedance wise.
  • Legendary70
    well they are both part of a htib. i just bought one a few months ago and the other years ago.
  • Tbone289
    Tbone289 Posts: 661
    rpf65 wrote: »
    They're not likely to be labelled directly on the speaker. Your best bet would be to look here: http://www.intl.onkyo.com/downloads/product_info/pdf/ht-s5400_ex_leaflet.pdf
    According to the specs, they're 6 ohm, so you will probably be fine.
    2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0
    edited March 2013
    Man, these turds have nothing better to do ?
