LS70 questions
attym
attym Posts: 33
edited November 2013 in Vintage Speakers
Hello, I have a pair of LS70s. I love the way they sound (and look).
I have a few questions that I'm hoping someone might be able to answer:
1. While removing one of the woofers, I accidentally pulled up a bit on the rubber surrounds. It didn't tear off, but an inch or so peeled up. I just pushed it back down and I don't think I hear any issues. Did I really mess this up? Should I go in and repair this or think about a new woofer...?
2. What prompted me to remove the woofer was when it was cutting out (more muffled and slightly distorted than fully out). if I touched it (pushed in on it) it came back and was fine for a bit. I took it out of the cabinet and then put it back together assuming it was a loose connection. It was fine for the rest of the night (last time I listened to it). Would you assume it was just a loose connection or is that the sign of a blown woofer?
3. I've read about upgrading the caps, etc. inside of these speakers. Does anyone have a list of components and perhaps a good source to buy them? I'm what you'd call a soldiering/cap noob so I need my hand held for this one.
Thanks!
Post edited by attym on
  • Tbone289
    Tbone289 Posts: 661
    edited February 2013
    See the LS70 schematic here for the capacitor and inductor specs: http://www.polkaudio.com/forums/showthread.php?38755-POLK-AUDIO-Speaker-Wiring-Schematics-amp-More-ALL-MODELS-except-SDA&p=434490&viewfull=1#post434490
    There are plenty of threads about quality replacement crossover components--try a search.
    2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0
  • skrol
    skrol Posts: 3,393
    The rubber surround should be fine. It lifts up to reveal the screws and should go right back in place with no issue.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • attym
    attym Posts: 33
    All this time later, looks like i need a new woofer.
