2 subs?
Legendary70
Legendary70 Posts: 18
edited February 2013 in Speakers
I have an Onkyo ht-s5400. I just purchased two tsi400's, a cs10, and a psw10.
Now I was wondering can I install another psw10 if i wanted to? If so i am not sure if my onkyo has another rca connection for a second sub? If it does not how would I go about installing a second one? thx.
Second question is I was checking my setup in the onkyo menu and noticed that my sub is set to 150 mhz or was it klz...one of the two. Someone told me to set it to 120?
In the same menu someone told me to set the two tsi400's to small so the sub can do all the work. When I took them off large there was a part in the menu that said double bass was off...what does that mean? can i get better bass with them set to large and double bass on? thx.
  • Loud & Clear
    Loud & Clear Posts: 1,538
    Easy as pie. If your receiver is without a second subwoofer output, just buy an inexpensive splitter (one male, two female).
    I find that two subs is vastly superior. I don't like to co-locate, but instead put one near the front left speaker and the other near the front right speaker. Bass is then smooth and spread out over the entire front of the stage. Good luck.
    Two Channel Setup:
    Speakers: Wharfedale Opus 2-3
    Integrated Amp: Krell S-300i
    DAC: Arcam irDac
    Source: iMac
    Remote Control: iPad Mini
    3.2 Home Theater Setup:
    Fronts: Klipsch RP-160M
    Center: Klipsch RP-160M
    Subwoofer: SVS PB12NSD (X 2)
    AVR: Yamaha Aventage RX-A2030
    Blu Ray: Sony BDP-S790
    TV Source: DirecTV Genie
  • Legendary70
    thx. sounds good. another audio forum mentioned to me why waste my money on another sub par (psw10) sub. why not just upgrade. well what do you all think here about that?
    i was just thinking of picking anohter psw10 because it is on sale at bb for $99. the one i b0ught last weekend is just awesome i think.
    any ideas? thx.
  • seabeerob213
    seabeerob213 Posts: 1,843
    wait for amazon or newegg to have the psw 505 for 190, i've heard the 10, and it was kinda lame by the standards set by my 505's and 110, the 505 has a lot more bass than 2 psw 10's, and you can run it along with the ten if you can get tem to blend well
  • B Run
    B Run Posts: 1,888
    I like dual subs but do agree you'll be better off upgrading to a better sub over having 2 PSW10's.
  • Tbone289
    Tbone289 Posts: 661
    ^This. You won't believe the increase in performance a PSW505 will give you over the PSW10. One 505 will handily outperform two PSW10s.
    2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0
  • rpf65
    rpf65 Posts: 2,127
    Double bass means that both the mains and the sub will recieve the lower freq signals. You tend to get more bass, but it may not sound as good if your mains have a problem with lower freqs. Sending lower freq signals to the mains also causes your AVR to work harder pusing the woofers at lower freqs. Setting the speakers to small will not allow double bass, because your telling the AVR you want as much lower freq signal as possible going to your sub.
    Leave the sub cross over where audessey set it at. What Audessey is telling you is that your mains are struggling a little with the lower freqs, and it is getting close to that limit. You can raise that number, but not lower it. That is a little high, you may want to rerun Audessy, and make sure the mic isn't being obstructed. Like not setting on a pillow/cushion, and not being blocked by furniture between it and the speakers.
  • Geoff4rfc
    Geoff4rfc Posts: 3,043
    All good advice here. 2 subs are definitely better than one, if you can afford the 505, go with it and try to blend the two, if you can only afford another 10, then rock on.
    Let the subs do the work, your overall sound should be better with mains set to small. Having the subs set to 120hz in the avr is good for a seemless blend.
    Be sure to post results.
  • decal
    decal Posts: 3,205
    I had a PSW10, it never performed to my expectations. I would opt for a better single then save up to get another one in the future if you feel you need it. That's just me, but like ZLTFUL said above, "As long as *YOU* are happy, don't give a crap what others think". BTW,
  • Dimehead
    Dimehead Posts: 31
    Go with 2 psw505. They are inexpensive and they sound awesome!!
    Front Stage
    Polk Audio MM6501 Door's
    Polk Audio MM5251 Kick Panels
    Back: Polk Audio MM651
    Sub : 2x Polk Audio MM1240dvc
    Front's : Soundstream Reference 700s
    Back : Polk Audio PA D200.2
    SUB : Soundstream Referencre 1000s 1ohm
    Alpine 3331 EQ
    Alpine cda-9856 Receiver
