Is there no other way
edited December 2003 in Electronics
Hi guys I need options, Ive been looking for a dts decoder and I dont see any options for 3 to 4 hundred bucks and I was wondering if the only option are the thousand dollar decoders. Any imput is better than none thanx.
Wish I was a polkologist then I could call my self Dr.warviper.
Post edited by warviper on
Welcome!
    Are you looking for a stand alone decoder? You might be better off picking up a new/used receiver that can decode DTS.
    people keep telling me that there is a difference and thats not the way to go. so basicaly you are saying that i should buy a reciver, a cheap one and use it as a pre amp right?
    is there any special way to hook it up will it work?
    thanx for the reply
    If you have a power amp than a receiver (pre-amp/processor) is the way to go. If you tell us what amp and budget you have then we can give you some recommendations.
    Graham
    Why are you looking for a DTS only decoder? There isn't much DTS only material out there. If you are using it for Video material mnay DVD players have the decoding built in.
    thanx for all the feedback but finaly bit the bullet and got a yamaha rx-v2300 got it for 550.00 respond on how you feel about it if you have one im having mixed feelings so far
    Good choice Viper. Yamaha makes a solid unit and it will decode DTS just fine (still curious about why you were orignally searching for a stand alone unit). You have seperate amps? Anyways, enjoy!
    Polk CS245i Center
    Polk RT55i Mains
    Polk RT25i Rears
    Polk PSW-350 Sub -in storage.
    Yamaha RX-V681 A/V Reciever
    Sony SCD-CE595 SACD Player
    Yea i was running to harmons the avr20s and they dont do dts or digital prologic:D
Welcome!
Welcome!
