Denon POA 1500 Glass
cwsmith68
cwsmith68 Posts: 434
edited February 2013 in DIY, Mods & Tweaks
Does anyone have any experience with the glass falling loose in the face of these Denon amps? Any suggestions on what type or brand of glue to replace it with? Procedures?
Main system:
Denon PRA-1500, Denon POA-2400, Denon TU-660, Denon DCD-2560, Denon DVD-2910, Denon DRS-640, Denon DP-30L II w/DL-301 mc cart, BSR EQ-3000, DCM Timeframe 600's
Post edited by cwsmith68 on
    F1nut Posts: 52,027
    Epoxy works well with glass.
  • cwsmith68
    Epoxy did the trick.
    Thanks F1
    Main system:
    F1nut Posts: 52,027
    Glad it worked for you.
