How well will the lsi series match to the psw 505
J9_ls1
J9_ls1 Posts: 20
I need a sub within the next few weeks, so the LSiW is not an option really. I think I am going with dual PSW505s. From what I can tell spec wise, they will match fine. Does anyone see anything that I may have missed? Any suggestions/comments would be great.
My current setup is LSi15s up front
LSiC center
2 pair LSifx for rear
Post edited by J9_ls1 on
  • ken brydson
    ken brydson Posts: 9,085
    edited December 2003
    How big is your room? What % HT vs music? I tell you what, 2 505's put's you at or above SVS PB2 $$. A much better option IMO.
  • PolkThug
    PolkThug Posts: 7,532
    I have dual PSW505's and love them. Just keep in mind that just because you have 2, doesn't mean you'll have "twice the bass". I have noticed a +10db difference on some Matrix Reloaded scenes on a RatShack meter. Where I used to hit 97db, I now hit 107db at the same volume. (Maybe in the near future I will do a thread on 1 vs. 2 subs)
    Regards,
    PolkThug
