My Adcom GFA 555 power switch does not work?
Dabutcher
Unit works fine. Just power switch is always on.Do I need to replace it from Adcom or can I just leave it on all the time? Does not seem to be getting hot? As always thanks for all the help . Darryl
Post edited by Dabutcher on
A lot of people keep them on all the time. I keep my sunfire on during the weekends but weekdays I turn it off via my panamax. Some people who use power strips just use that to turn them off, or you can just replace the switch.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
You could plug into a power strip and switch it on and off from there.
it's very easy to replace...i think i got mine from parts express...they have the drop in replacement...
Or, you could just use one of these that will power the amp on automatically when you turn on your AVR:
http://www.amazon.com/Smart-Energy-Saving-Autoswitching-Technology/dp/B000P1QJXQ/ref=sr_1_4?ie=UTF8&qid=1360345704&sr=8-4&keywords=smart+power+stripTV: 65" Samsung QLED 4K
AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier -
I looked on parts express and entered power switch in search. Nothing? What should I use for search key word? Thanks for all the help. DMIT Magnum MH-750, Monster HTS 5100MKII, Sony 77" Class - A80CJ Series - 4K UHD OLED,PS4, Def Tech 15” sub,LSIM 706c, Sunfire Signature Grand 425 x 4,Parasound hca 120, LSiM 702 x 4, Oppo 103D, SDA SRS 1.2, Pioneer Elite SC63 , Pioneer Elite BDP-05 “Why did you get married if you wanted big speakers?”
give them a call
