rtia7 and emotiva amp.
Hey all,
I got myself some rtia7's, but for the time being am on an amp budget and was wondering if the Emotiva upa-500 would cut it (seeing as so many speak well of the xpa)? For now I am just using the 2 speakers, but may upgrade at some point.
Will they play, of course, will they operate to their full potential, no. Save & get and XPA.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
I would rather have speakers that actually do something, instead of waiting and saving. Couldn't I get something like the xpa-2's later, and use this for surrounds or something?
Of course you can, if you have enough outlets and whatnot, you can buy monoblocks if you want. A receiver will run your speakers right now, they just won't be powered to their full potential.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
First of all, welcome to the club. Second of all, I agree with Frizz.
Take it from someone that's done the same thing you're willing to do, compromise. Save up and do it right the first time. You've got killer speakers, they really deserve great power.Marantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB9000-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-11.2 -
I recently picked up a 2ch Parasound amp (80wpc) for use down the road. I also have Rti-A7's which are being driven by a much larger Sony ES amp.
Just for fun I hooked the Parasound up to the A7's. It sounded very nice, but I could tell the amp was running out of juice trying to push the towers.
When I switched back to the Sony amp (200wpc) the A7's jumped to life and I have never felt like the amp was even breaking a sweat.
As others have said, save your pennies for a higher power amp. I thought there was an Outlaw monoblock in the FM right now. Even though it is only one amp, they pop up for sale all the time so it wouldn't take too long to find a mate for it. The Outlaw would smoke the EMO. -
+1. Don't compromise. Save up and put some power to the A7's which you can do at a reasonable price used or wait for the higher emotiva. While playing the A7's with an moderately powered AVR (don't know what you have) watch the volume level. Keep it at a moderate level until your amp purchase._____________________________________________________________________________________________
DAC: Bricasti M1SE
Pre/Pro: Marantz AV8805
Subs: 2 - Rythmik F25's
Room Treatments: GIK Acoustics -
I am bypassing a receiver, and connecting directly to my htpc. As the 7's have the connectors already to the top and bottom, couldn't I run 2 channels to each tower giving 160w to each?
if your AVR struggles w/4 ohm loads, that may get some improvement as each channel will see 8 ohms. Full range the A7s are 4 ohms below 125 hz.I am bypassing a receiver, and connecting directly to my htpc. As the 7's have the connectors already to the top and bottom, couldn't I run 2 channels to each tower giving 160w to each?
Can't hurt to try it. Either way take easy w/ the "loud" knob until you add a sub & higher quality power.
TonySamsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
*all connected w/Premiere ICs
