Music only receiver suggestions
Bob in WI
currently Yamaha RX V850 driving Monitor 70s. Music only / room is not that large, stereo only, not likely to surround sound. No sub now & none wanted. Current receiver is 80 watts per. Any advantage to more power? If so, suggestions? I see a lot of nice HT stuff but thats going to have bells & whistles I don't need to pay for. Don't know if its worth looking into upgrading & if so, some ideas on where to start. I'm not afraid of older equipment if it suits the need. Listen mostly to classical, jazz & voice via LPs, CDs & FM radio (I have the most awesome antenna). TIA.
Post edited by Bob in WI on
I have a simple inexpensive setup in my office that blows me away eveytime I listen. SOme of that is due to crossover upgrades and other tweaks to the LS90.
Pioneer SX-950 ($200) (soon o be replaced by Anthem AMP 1 and Wright WLA-12 preamp)
POlk AUdio LS90 ($150) Tweaked ($100)
Pioneer Elite DVD/CD/SACD ($200)
Apple Airport Extreme ($77) stream music from music server.Speakers: SDA-1C (most all the goodies)
I missed your question, SOunds like you already have a receiver and speakers (Yamaha RX V850 driving Monitor 70s) and want to know if you would benifit from more power.
Before I amswer, how do they sound ? ARe you moved when listening. If you are then power dont matter.
But to answer your question, more over head is always better.
I am going down in power from the Pioneer to anthem AMP 1 but I bet there will be a sound improvement.
Let your ears be the judge.Speakers: SDA-1C (most all the goodies)
Vintage Kyocera R-851. (if you can find one)
Budget?
http://www.outlawaudio.com/products/rr2150.html
http://www.pioneerelectronics.com/PUSA/Home/Audio-Components/Hi-Fi+Audio/A-20
Those would be on my short list, if I was buying new for two-channel. -
Adcom 555 if you have the capability. The HK 3490 is very nicely matched to the 70's.Main
Parasound P5
Parasound A21
CA music streamer
marantz 6005
Clear Day dbl.shotgun
Morrow Xlr
1.7 Maggies
Bedroom
adcom Gfp750
Adcom 555
Rotel 1072
CA tuner
LsiM703
Clear day dbl shotgun -
I would recommend one of the HK stereo receivers, I can't imagine anything better in their respective price ranges.
Use the tuner in the current receiver and buy an integrated amp. This is one of the best for the money today.
http://www.audioadvisor.com/prodinfo.asp?number=CA851ALumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Good advice; I cannot vouch for the linked product, but the strategy is good, and there are myriad good choices, new and not-so-new.Use the tuner in the current receiver and buy an integrated amp. This is one of the best for the money today.
If you've gotta have a 2-channel receiver, though...
Since you have something that works, I'd be patient and set up some RSS feeds for your local craigslist to start watching for brands/models you might want. I needed more power for a two-channel setup and, after months of looking, finally found a NAD 7400 that had recently been completely refurbed. Sounds amazing, and the price was far less than anything comparable would be today.
The great part about craigslist is that locals who are audio-junkies are often happy to have you bring your own gear to test with. When getting the NAD, I took my speakers and set them up in his listening room to see how they worked together. Made for a solid test. Also a great way to get to know some of the audio locals.
If you're patient, you can get a great deal on really cool equipment.5.1 theater - Pioneer SC-07, Mirage OMD-CC center, 4 x Mirage Omnisats, Boston Acoustics VPS-210 sub
2.1 living room - NAD 7400 integrated, 2 x Platinum Audio Duos, MIT Terminator4 cables
2.1 bedroom- Arcam Solo, 2 x Mirage OMD-5's
FOR SALE - Genesis Servo-10 sub, Genesis Servo-12 amp; Martin Logan Dynamo sub; Mirage MM-6 sub; Harman Kardon DPR-1001 7.1 receiver -
Many good choices in the Integrated category these days. On a budget I'd recommend NAD or Rotel. I've had both a Rotel Receiver and an NAD integrated and enjoyed the extra dynamic headroom each displayed. I'm a fan of dedicated controls on the receiver itself, (as opposed to using a remote for frequently used functions) and they both follow that design intent.
For loads of watt power, a vintage Carver receiver can be had fairly cheaply.
http://www.ebay.com/itm/Carver-MXR-2000-2-Channel-200-Watt-Receiver-/140908251467?pt=US_Stereo_Receivers&hash=item20cec9494b -
I agree with mhardy. I love my Yamaha CR 2020 receiver and would never part with it. If you are looking for an excellent vintage receiver, it is one of the best, if not THE best.
... I am unaware of any all-around better sounding/performing vintage receivers.
...although there are flashier and pricier ones.
Thanks for the suggestions & ideas. I'm on a budget (bought the Monitor 70s for $350). With the new speakers I hear "fuzz" I hadn't heard before. Not always but sometimes & source does not seem to be a factor. Also, I hear all the instruments of the orchestra but they don't jump out at me. I don't know the correct terminology; presence maybe? I know the surround sound amps (& mine can not bypass it) have wizardry that may be affecting the sound in 2 channel. So that's what got me to thinking maybe I should look at a replacement. There's a Carver M1.0t amp on CL for $350 but I need to think this thru before I start writing checks. As one poster pointed out, I have music now - patience can be my friend. Thanks again to all. Great ideas to get me thinking....
I'd love to match an R-851 against the Yamaha for a SQ "shoot out" ! My $$$ would be on the Kyocera.
http://stereonomono.blogspot.com/2012/07/kyocera-r-851.html -
With the new speakers I hear "fuzz" I hadn't heard before. .
Bob, "fuzz" as you put it, is not a sound quality characteristic of not enough power. Check your connections, wire. Also make sure you set up the inputs in the receiver. If your using any of those jazzy sound fields....don't. Pure direct mode for 2 channel is your best bet, given you have a decent source. Speaking of....what is your source and cables ?HT SYSTEM-
lsi 9's -
You know, a lot of guys scoff at the idea of using or perhaps misusing an AVR for a dedicated 2 channel but there are many very wonderful pieces to be had for peanuts out there. Guys just shove the older units out the door to get the latest 11.2 channel or 3d or audassy or whatever and a 5k unit is available for a few hundred. I have been watching on e-bay a few of the Yamaha past flagship units and 3-5 hundred will get you a rxv 1 rxv2700 ( I have one) or even one of the z series. I love the sound of Yamaha.Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's. -
michael1947 wrote: »You know, a lot of guys scoff at the idea of using or perhaps misusing an AVR for a dedicated 2 channel but there are many very wonderful pieces to be had for peanuts out there. Guys just shove the older units out the door to get the latest 11.2 channel or 3d or audassy or whatever and a 5k unit is available for a few hundred. I have been watching on e-bay a few of the Yamaha past flagship units and 3-5 hundred will get you a rxv 1 rxv2700 ( I have one) or even one of the z series. I love the sound of Yamaha.
There is truth to this. Find a used Sony DA-7100ES, five channel AVR at 175W/ch. The last decent AVR Sony built before the MBAs took over. I am finally retiring mine (used as a pre/pro the last 5 years), but I suspect it is still better that what 99.9% of people are using. Find a sister NS9100ES SACD player, connect it via a FireWire ILink cable, and you have a killer system. I bet you can find both for a $1000. No you cannot buy mine. They are now spares for emergencies.Lumin X1 file player, Westminster Labs interconnect cable
I sure wouldn't have a problem with a receiver for 2 channel, but it would have to be a damn good one. Which btw, are out there and on the used market, a steal. I still miss my B&k 307 receiver, sold it for 3 bones too. Gave a nice couple just setting up shop together a great deal.HT SYSTEM-
lsi 9's -
A Denon AVR 5800 can be picked up for around $400. I continue to be amazed at the SQ. Powers my SRS's beautifully. I NEVER thought a receiver could drive them anywhere close to their potential, but I gotta admit, Denon made this one right.SRS 3.1TL
Harman Kardon Citation 5.1
Anthem AVM2 -
Look at a Onkyo TX-8050 or tx-8255 . Great stereo receivers.
If buying new, I'd go straight for the Outlaw RR2150 and be done with it. Used? Endless possibilities. And if you decide to get into separates instead of getting a receiver... Even more endless.
Monster AVL-300, HTS-2500 MKII -
Outlaw RR2150 - I never heard of Outlaw & never heard an Outlaw. What a cool looking receiver tho. Kind of art deco...
That's a great choice if you want to go with a "new" stereo receiver in the less than $1K range. Good sound, good power!
outlaw reciever was favorably reviewed by either stereophile or TAS ( cant remember which ). HK has a new line of 2ch also. but I would recommend finding a vintage marantz 2270 or similar or a pioneer 1050, 1080, or yamaha like shown above and have the electrolytics replaced and refurbish the unit. the design philosophy of the vintage units was very very good.
Bob, I just had an eye-opening experience with regards to my Harman Kardon HK3490. I've had it for over a year and it continues to impress. I recently got a steal on a pair of Rotel RB981 external amps that are regarded pretty well and they can't compete with the HK3490.
So I suggest you check out the HK3490. The sound is warm and rich and I look forward to listening to my SDAs powered by it every day.TV: 65" Samsung QLED 4K
AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier -
what is the value of the HK3490 if one were to be found used ?
I'd say 200-300! With 300 being a little high because these receivers are sometimes discounted NEW for 299. Or at least they used to be?
