Setting up 2 MM100s
Systems
Systems Posts: 14,873
edited December 2001 in Car Audio & Electronics
I am purchasing two Momo 10s for my car and had a couple questions about the setup. First off wanted to check to see if my amp would be pretty good for this setup. I currently own an MTX1000D which I believe should push the subs fairly well if I wire them in a 2 ohm load. As for the actual box I had several questions. I want to mount two of the subs so should I use a dual enclosure using shared air space or should I use a dual enclosure with individual sealed compartments for best performance. I found a box I may be interested also for using as the enclosure and wanted to get some feedback on it. It's the OBCON Sealed Small Enclosure for Dual 10s. It's got an enclosure space of .66 cubic feet for sub which I figured should be fine for small space like the Momos. If anyone could take a look at this box: http://www.sounddomain.com/sku/OBCSS10266 and let me know what they think I'd appriciate it.
Testing
Testing
Testing
