Sub with RG6 Hookup question
pcgorilla
We had our home pre-wired for Speakers/Sub inwall.
They have an (cut) Quad SHielded RG6 in the wall for the sub. Silly question I know, but I hate the communists at Radio Shak.
What is the adapter called that I need for my Polk 450 Sub and the back of my receiver?
Post edited by pcgorilla on
Hello,
I am assuming there isn't any kind of connecting plugs on either end of the RG6, correct? If so, you will need to install an RCA plug on both ends of the cable and since RG6 is a larger diameter coaxial cable, you would want to make sure the RCA plug's barrel will fit over the diameter of the cable. If not you'd have to drill out the opening in the plug's barrel to allow the cable to go over.
Regards, Ken -
thanks
You're welcome!
