sl2000 tweeter problem after installing new interconnect
Bigbang
So... I bought a pair of SDA CRS+'s and have been enjoying them for the last two weeks. They didn't come with an interconnect cable so I temporarily stuck some speaker wire in the interconnect slots and taped it to secure it until I could install a more permanent solution.
Yesterday I installed a pair of new speak on connectors. I took the old interconnect termination out and drilled out a wider hole and installed the new connectors. Screwed them down, applied ample glue to seal them and put everything back together. I plugged in my new interconnect and to my shock my sl2000's (both of them) started making this horrible distortion/crackling at about 70db. Anything lower and they sound great.
I know these tweeters are not ideal and need to invest in some rdo-194's soon but does anyone have any idea why both 2000's would do this after replacing my interconnect cable. The 2000's are not even in the dimensional array, so the interconnect replacement should not have played any part in it. Could I have bumped the crossover and hurt the poly or some other solder joint? Does anyone have any idea why this specific problem would happen with both tweeters after an interconnect change? Weird, right?
I like to listen, tinker, listen and repeat.
Post edited by Bigbang on
Are your CRS+ pin/blade connectors? If so you should NOT use two wires to connect the speakers together. One wire between the pins is what you need. No wire between the blades of each speaker. IF you have two wires going between the speakers stop using them now!
- SDA 2BTL · Sonicaps · Mills resistors · RDO-198s · New gaskets · H-nuts · Erse inductors · BH5 · Dynamat
- Crossover upgrades by westmassguy
- Marantz 1504 AVR (front speaker pre-outs to Adcom 555)
- Adcom GFA-555 amp · Upgrades & speaker protection added by OldmanSRS
- Pioneer DV-610AV DVD/CD player
- SDA CRS+ · Hidden away in the closet
Pin-Blade:
What harm would come from connecting the two blades together? It'd be the same as having a common-ground amp, but with less resistance. The blades are connected to the negative speaker terminals within the speaker cabinets, connecting the two blades together with a wire is electrically the same as connecting the negative terminals together with a receiver/amplifier chassis.
Now, get the polarity wrong in one of the cabinets--pin from one cabinet connected to blade of the other cabinet, instead of pin to pin--and evil stuff is bound to happen due to a more-or-less dead short across the common-ground amp. I'd expect the amp would fry before causing tweeter problems, but what do I know?
Blade/Blade
Again, polarity has to be correct. Had a guy mix up the wires on a (1B???) a few weeks ago, and the speakers sounded terrible. Colored wire of one speaker (blue or black SDA socket wire in that case, depending on which channel) connects to the white wire of the SDA socket in the other cabinet . This REQUIRES two conductors in the SDA interconnect cable. -
They are blade/blade. I should have added that.I like to listen, tinker, listen and repeat.
Did you wire blue to (opposite channel) white, black to (opposite channel) white?
I confess my stupidity so that others may learn. I have black left going to blue right. And I have white going to white. I'll switch this and report back.I like to listen, tinker, listen and repeat.
That was it. I switched the pins on the IC and now everything works perfect. It's a mystery to me what the would mess with the high pass but I'm always learning.I like to listen, tinker, listen and repeat.
Ok, I have a question. I've got a pair of sda's that are blade/blade I made my own cable, are you saying that the cable doesn't go big blade to big blade, and narrow blade to narrow blade?
Should it go big blade to narrow blade?
I've got a crackling in the sda tweeter on both speakers, I've swapped them around to no avail, I thought I might have a crossover problem, you mean It might be as simple as swapping one end of my homemade cable around.? -
Others can chime in but yes the original IC cable was crossed. Let us know if that helped. I love when my stupidity helps others.I like to listen, tinker, listen and repeat.
That was it. I switched the pins on the IC and now everything works perfect. It's a mystery to me what the would mess with the high pass but I'm always learning.Anthony Hinton wrote: »Ok, I have a question. I've got a pair of sda's that are blade/blade I made my own cable, are you saying that the cable doesn't go big blade to big blade, and narrow blade to narrow blade?
I've got a crackling in the sda tweeter on both speakers, I've swapped them around to no avail, I thought I might have a crossover problem, you mean It might be as simple as swapping one end of my homemade cable around.?Others can chime in but yes the original IC cable was crossed.
For my 1Bs, the SDA socket wiring in the cabinet is like this:
Large blade (blue wire) on top of small blade (white wire) = Right channel cabinet
Small blade (black wire) on top of large blade (white wire) = Left channel cabinet
I'd be concerned about defective tweeters in your case. I suppose it could be a defective crossover--cold solder joint, cracked trace on the PC board, etc...but I'd suspect tweeters first. -
Anthony Hinton wrote: »I've got a crackling in the sda tweeter on both speakers, I've swapped them around to no avail, I thought I might have a crossover problem, you mean It might be as simple as swapping one end of my homemade cable around.?
If you've swapped the tweeters from SDA to Stereo, and the problem stays with the SDA position, it's almost certainly a crossover problem. I'm looking at the schematic for the SDA 1A, the SDA tweeters have a polyswitch. Seems to me crackling is a symptom of defective polyswitches; as is premature cut-out. I suppose rapid opening/closing of the polyswitch would sound like "crackling".
Anyway, if those are 1As, (or another model using polyswitches for tweeter protection) that's where I'd start. -
Thanks Schurkey for your help.I like to listen, tinker, listen and repeat.
As so often happens, I ran out of edit time on my previous post.
Thank you. Thank you very much.
