ok i aint sellin' da sda1's but.......
mesquitehead
ok guys....i have read up on the sda1's and understand i need more power....mind you i have a lady and 3 little ones to fend for so value is a major consideration....i have a (sigh) harmon kardon ht receiver with pre outs and want to add a good bang for the buck 2 channel amp....ANY SUGGESTIONS......p.s. if you dont have the lyle lovett dts disc go get it , sounds like heaven.....but then again maybe its just a texas thang......
"Thats great... but how does it sound"
http://www.burginmcdaniel.com/
http://mixonline.com/gear/reviews/audio_burgin_mcdaniel_komit/
Yamaha RX-A820 (networked with wireless bridge), Carver M-1.0t, Carver TFM-35, Carver C-1, Polk SDA1c's (x2 pair), Polk RTA 8tl's, Polk RTA 11tl's, Polk Monitor 5, Polk CS 400, Polk PSW 650, Rega Planar 3, Sony DVPNC555ES SACD/DVD, Panny 65" Plasma, Roku
2007 Tundra 5.7 TRD DC
Pioneer DEH-80PRS
Polk SR6500
SI BM 12" subs
Zed Gladius
Zed Deuce
Pioneer DEH-80PRS
Polk SR6500
SI BM 12" subs
Zed Gladius
Zed Deuce
Get a used Carver off eBay. Easily the best bang for the buck. A M1.0-t should be able to be found for less than $400. 200W per channel.
WesLink: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d -
Look over at the Flea Market, there is a guy selling a great THX certified NAD amp for a good deal, under "Year End Clearance"
Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
