Battery Opinion
geralopez
Have some one experience with this batt.?
Tsunami PP880-BTY Yellow Top.
Tsumani Battery -from Nissan Performance
Tsunami Battery -from Tsunami website
Battery Price
Have somebody any other brand?
Thank you
GLopez
Battery Price
Thank you
GLopez
Post edited by geralopez on
When in doubt, stick with Optima. They are tried and true.Testing
Testing
Testing -
Thanks Mac
Have you any link? -
many of the car audio sites carry optima batteries too
try sounddomain, onlinecarstereo, amongst others, you might find em for cheaper
-Cody -
iv seen optima batts at auto zone might check there toTesting
Testing
Testing -
dude -- 900 cca / 1100 ca energizers / die hards / interstate batteries will be just as friggin good.
why waste your money unless you're going to play the audio for hours on end with the car not running.The Artist formerly known as PoweredByDodge -
What do you think is under that hideous battery terminal on the Tsunami batt?
I think: It is just part of one universe dedicated to the car audio,
If it exist and it do not alter or damage your car audio setup, use it, if you have the money to buy it, go for one of them an install it.
I'm not sure if I really need it. I just want to protect the whole electrical system of my car, you know, it it full of electronic parts. -
did i miss it?
or did it not even say how many cc or ccas youre getting?
-Cody
