How hard is it to install a new cartridge?
nspindel
nspindel Posts: 5,343
edited January 2013 in 2 Channel Audio
I'm having some thoughts about trying out a different cartridge in my turntable. I have a Shure MX97e, which has been great to get me off the ground. But I'm thinking of trying something different, perhaps a Grado. Just how complicated is it to properly configure the cartridge. Is this something I can do myself if I've never done before? Or do I need a pro to do it for me?
Post edited by nspindel on
  • PSOVLSK
    PSOVLSK Posts: 5,400
    edited January 2013
    I'm as amatuer as they come and I changed the cart on my Pro-ject Debut iii turntable. Actually changed to the Shure you are getting away from. Very thin wires so you have to be pretty delicate, but I didn't think it was too difficult of a job.
  • nspindel
    edited January 2013
    The Shure is a great cartridge, just looking sto step up the food chain a bit!
  • thsmith
    thsmith Posts: 6,082
    edited January 2013
    It is not to bad as long as you are prepared and armed with the knowledge on how to do it. You will need a well lit work area, tweezers, an alignment template, patience, patience and more patience.
    I probably went overboard but since I was installin a $1k+ cart I used a best tractor made for my TT, USB microscope, digital scales and fozgometer.
    It was worth it.
  • nspindel
    edited January 2013
    Sounds like I should get someone to do it for me!
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited January 2013
    thsmith wrote: »
    It was worth it.
    That sounds to much like surgery...
  • dromunds
    dromunds Posts: 10,139
    edited January 2013
    You can do it yourself. Like PSOLVSK said, its delicate at times. Go to Vinyl Engine (I believe is the sight) and there's some stuff on cart alignment. You can plug in some dimensions for your turntable and arm and it will provide you an alignment template that you can print off on hard stock and put on your platter to help align the cart once mounted on the arm. If you want a more expensive alignment method, you can google the subject and find one that costs $75 and is made for your specific equipment. You have to deal with very small wires in the back of the cart, but you can use tweezers to slide them off and on. The color coding is obvious. You will have to balance the tonearm and your instruction manual will outline that, its usually very simple. You may have to change the vertical tracking angle and also should be explained in your manual. Give it a shot. Google around and there's alot of info on it. Make sure you put the guard down covering the stylus while installing. You don't want to break that off.
  • Obsession18
    Obsession18 Posts: 191
    edited January 2013
    I recently installed an Ortofon 2M Blue on my new VPI Traveler; this involved the following 3 adjustments (after the cart was mounted):
    VTA - Vertical Tracking Angle, on my Traveler this is set by raising or lowering the tonearm so that it is parallel to a record on the platter, use an index card bent in half long ways setting on the record to eyeball this.
    Cartridge Overhang - once your done with VTA use an alignment protractor (Google is your friend here) to get the stylus in the right spot and to also make sure it is square and not riding sideways.
    VTF - Vertical Tracking Force, this depends on your table, some require you to zero the weight (arm floating level) then dial up the tracking weight, my Traveler came with a scale.
    2-Channel System
    Analog: VPI Traveler TT, Audio Technica 150MLX, Pro-Ject Tube Box DS
    CD Player: Jolida JD-100 Preamp: Cambridge 840E Amp: Odyssey Kismet Stereo
    Spkrs: Tyler Acoustics Linbrook Signature Systems
  • dkg999
    dkg999 Posts: 5,647
    edited January 2013
    It's tedius, however not overly difficult. A good tracking weight scale and a MFSL geo-disc are your friends.
    Also make sure to check to make sure the cart you want is compatible with your tonearm.
    DKG999
  • George Grand
    George Grand Posts: 12,256
    edited January 2013
    Damn shame you can't get Dan to fly out and hook/tweak your whole rig up top to bottom. He's a pro.
    Tedious.
    SCompRacer Posts: 9,122
    edited January 2013
    nspindel wrote: »
    Of utmost importance, you need to have a hangover.....no wait, it's hungover....no, wait, its......overhang, yeah, overhang!:cheesygrin:
    Overhang is the amount the stylus extends past the center of spindle. However not all arms will extend over center of spindle so you gotta use a protractor. Once upon a time, some manufacturers with removable headshells actually had a mark where to align the stylus for proper overhang. Or contained a plastic gauge to set it.
    Good luck!
  • wkjeffers
    wkjeffers Posts: 139
    edited January 2013
    I second the geo disc and a good shure tracking weight scale ($50 and $30 respecively ) and then you will have the tools for the future. also some small needlenose pliers and patience. not hard to do.
  • Upstatemax
    Upstatemax Posts: 2,798
    edited January 2013
    What Grado cart do you plan to go with Neil?
    IIRC, some of those cart leads were pretty fragile on that arm. If you wanted to, you would not need to do a full rewire on that tone arm. Just the half that holds the head shell and that would give you fresh wires and clips to the cart.
