W/C is better rti70, rti100 or rti150?
Need to know asap coz i got a good deal @ circuit city for rti150 for $219 each (open item). I have csi40 and fxi30 with no sub. I have a new pair of rti100 and thinking of replacing it with the 150s. Is this worth it? Running on SONY 1070 right now and thinking of getting a ADCOM to power my floor front spkrs.
Thank you.
Thank you.
Godspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
Post edited by doggie750 on
I know there are a couple of threads that were posted here before. If you will look around this forum, you'll know that the 70s is the right way to go. I just don't have the specialty yet to explain to you why they stand out from the rest?
Somebody! help the new member out for crying out loud!
I will give you the link once I find the threads....;)
glennHT:
DENON AVR-3803
DENON DVM-1805
SONY DVP-NS300
SONY 36' HDTV Wega
ADCOM GFA-555
ADCOM GFA-555
ADCOM GFA-2535
ADCOM ACE-515
POLK RTi70's (Bi-Amped)
POLK CSi40
POLK FXi30's
POLK RTi38's
POLK CSi20
POLK PSW 450
SVS PB2 Plus
2 CH Stereo:
AudioSource Pre/Amp 1
Hafler DH-500
Sony CDP-CX235
Monster Cable HTS3500
SDA SRS 2.3tl -
The 150's require alot more power to run at there fullest compared to the 100's or 70's. The 100's would be better if your power was in question but IMO at the cost of the mids. The 70's will give you better mid but at the cost of the lows and would be better run with a sub.
In order they would be IMO.
150's W/enough power best all around (high, mid, low's)
100's (high, low's) lacking in mids
70's (high, mid's) lacking in lows
In the end it's your ears that will tell you wich way to go, if you eventually go with a sub. then the 70's IMO would be best.
Good luck
Dave -
I own a pair of RTi150s. I auditioned them alongside RTi100s and RTi70s and i have to agree with Dave Shepard's analysis of the three.
I found that with adequate amplification, the RTi150s were the most pleasing to my ears. I'm bi-amping my RTi150s and, after having them for 1.5 months, they still take my breath away sometimes.
Rgds,
--Pete -
I had my RTi150's ran on the Denon AVR3801 (100wx7) for months and the Denon never clipped (I don't turn it up beyond -10 db) before I got an Adcom GFA5500 to power them. I can tell you that the 150s can reach lower, and sound better with the Adcom. So, if you are going to get the 150's, I would recommend saving up another $600 on a used 200 wpc minimum amp to power them properly.
With the Adcom, each 150 reached lows beyond my previously own PSW350. But that was not enough, I went out and got a SVS PB1-ISD and place it in the rear of the room opposite the 150s. I set my AVR3801 on Main+LFE for the bass signal, and now I am in heaven: tight, strong, quick and clear bass all around.
So, the 150s sound great with a multi-channel receiver, but they sound even better with addtional amp. Also, you can add a small sub later even when you already have the RTi150's to acheive high level of bass volume without muddiness.
