Audible running noise from Denon 3910
Mr. Sharpe
Mr. Sharpe Posts: 1,359
edited January 2013 in Electronics
So while I'm watching movies on the player I can hear it running. Is there anything I can do about this? it used to I couldn't hear it at all except for when it was loading a disc. Maybe replace the motor? or maybe dust it off?
This is my player, I use it and just want it to be quiet again and know how to maybe fix it if it happens again. many thanks in advance:)
Home theater:
43” Westinghouse Displayer
Marantz UD-7007 Player
Emotiva MC-700 Processor
Adcom GFA-5006 Amplifier
Parasound Zamp Amplifier
Ethereal ESO-1 Power Conditioner
Klipsch RC-10 Center
Klipsch R34c Fronts
Klipsch RB-41 Surrounds
Polk audio PSW-505
Stereo:
Polk audio RTA-12c’s fully upgraded crossovers
DIY 12tc braided speaker cables
Denon DVD-5910ci Spinner
Parasound P6 Preamplifer
Parasound HCA -1500a Amplifier
Post edited by Mr. Sharpe on
    F1nut Posts: 52,273
    edited January 2013
    The spindle motor needs a lube job.
    edited January 2013
    I'm gonna use that line on the wife Jess. Wish me luck.....
  • Mr. Sharpe
    edited January 2013
    Sounds easy enough I suppose. I'll have to do that tomorrow. I figured it needed some kind of lubricant, but to be totally honest for a DVD player at this price.... and I'll stop right there. I've never heard my old 2800. really sad
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
    F1nut Posts: 52,273
    edited January 2013
    It's a common maintenance issue with any disc drive motor and that player isn't that much money. I use WD-40 injected with syringe.
  • Mr. Sharpe
    edited January 2013
    I know it's not that much compared to some. Sounds good though. thanks a bunch. I hope you're enjoying those eso's. they are pretty awesome:)
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • Mr. Sharpe
    edited January 2013
    Okay I opened it up, should I oil from the side? the back of the motor has no moving parts.
    So many things in this player, ridiculous, I"ll my old Pioneer only had 3 or 4 boards in it total, this has 6 or more.
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
    F1nut Posts: 52,273
    edited January 2013
    I inject small amounts at a time right onto the spindle shaft at the top of the motor, then spin the plastic disc that actually spins the CD by hand a few times and repeat. Wipe up any excess oil before using. Your motor may be different than the ones I've seen, but should be the same basic principle.
  • Mr. Sharpe
    edited January 2013
    okay then sounds good. I'll try that, thanks again.
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • Mr. Sharpe
    edited January 2013
    so I put oil on the top of the spindle. and down around the bottom of it best I could. does it take a few minutes of running before it quiets down a lot? I can still hear it, but it has gotten quieter. I had to drip the oil out of a little syringe I had because I didn't have a really tiny one.
    Glad I found some disassembling instructions online or I wouldn't have figured out how to put the tray back in, it has a metal bar that is slides on. ridiculous.
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
    F1nut Posts: 52,273
    edited January 2013
    If you got enough oil in there, it will be quiet right away.
  • Mr. Sharpe
    edited January 2013
    maybe I need to oil it again? I can hear it from where I'm sitting now:( I'm not sure why, I could barely hear it while it was sitting on the table playing a disc. I'll try again.
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
    F1nut Posts: 52,273
    edited January 2013
    Yes, I would try more oil. If you can't get it quiet with more oil, the sleeve bearings are shot.
  • Mr. Sharpe
    edited January 2013
    sleeve bearings inside the motor? What do I do about that? nothing? get a new one?
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
    F1nut Posts: 52,273
    edited January 2013
    You bet, something has to keep that shaft spinning true.
    If shot yeah, you'll need a new motor.
  • Mr. Sharpe
    edited January 2013
    since we've been speaking it's not as loud. Maybe it is just needing more oil about 30 minutes ago it was loud enough I could hear it from the couch. now i can't hear it, it must be oil.
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
