CSR and CSi10 question
canu49
canu49 Posts: 3
edited January 2013 in Speakers
I just purchased a CSR and have a question. Per my receiver manual I should set the bass management to "large", based on the size of the speakers. I read on the Polk site that, for the CSi10, they recommend you set it to "small". The CSR manual doesn't mention this, but they're the same size speakers and very close to same size cabinet. Could anyone shed some light on this. Thanks
  • seabeerob213
    seabeerob213 Posts: 1,843
    edited January 2013
    as a generalrule of thumb, if you have a subwoofer run it as smal with a crossoover set to 80Hz, if you dont, run it large, with both try adjusting the settings until it sounds good to you
