Quick question about 3.1TL's -- can they fit in a 2005 Camry?
Mystery
Mystery Posts: 2,546
edited January 2013 in Vintage Speakers
I've brought Sony SSU-4000 around 46.5 inches tall in the Camry before (one in trunk another in the back seat) but these are 48" so not sure.
Also, no IC cable so can I test with a speaker cable crammed in the IC jack?
Post edited by Mystery on
  • dpowell
    dpowell Posts: 3,068
    edited January 2013
    Probably not the pair. maybe one at a time but that'd be pushing it.
    polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, Pass Labs X1, Marantz 7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Moon 380D DAC, EPSON Pro Cinema 6050
  • Mystery
    edited January 2013
    That's what I thought and with a long drive, I don't want to take chances on the size.
    I'll have to re-schedule so I can bring bigger vehicle.
    BTW, what's a deal price without IC cable?
    He's asking $350.
    I've to take some speaker cables in case they have modified jack and IC cable from CRS+ to test the SDA drivers.
  • thsmith
    thsmith Posts: 6,082
    edited January 2013
    I would think $350 is a deal.
  • naturallight
    naturallight Posts: 689
    edited January 2013
    I just don't get it....I must live in a stereo Hell land. How you can get a set of 3.1TL's for $350 bucks..I don't get..at all.
    But i suppose i have to say ..happy for your find..wish i could do the same....LMAO
  • proffitt
    proffitt Posts: 157
    edited January 2013
    Wow, 3.1TLs in a Camry? That'd be a tight fit.
    The soundstage would be extremely limited, and you'd have a hard time spacing them far enough from the doors/windows to get the most out of their spatial effect. Can you get a Jensen for them?
    But they'd look cool stopped at the intersection. and they sure would thump. :cheesygrin:
  • Schurkey
    Schurkey Posts: 2,105
    edited January 2013
    My 1Bs came home in an '80 Honda Civic.
    Tape measure is your friend.
  • Mystery
    edited January 2013
    Haven't seen them in person so not sure if all drivers work and seller doesn't have pic of the back so no idea how good/bad the cabinet is. That all changes price drastically. Even if only 2 drivers or tweeters are out, that's another hundred.
    Plus, he mentioned there is a nut in the back where the SDA cable goes.
    I'm assuming someone replaced jack and put a custom jack for the cable. :confused:
  • Mystery
    edited January 2013
    Schurkey wrote: »
    I hauled a pair of Sony SSU-4000 that are 46.5" high so 1C's should fit fine.
    1C --> 11-1/2"D x 16-9/16"W x 44"H
    However, 3.1TL are 13-3/8"D x 15-3/4"W x 48"H.
    48" high is the concern here.
    If I can't close the door, then it's no good.
    Plus, there is no hurry. I already have SDA-2B's and CRS+.
    I'm trying not to buy more speakers but they show up and I get tempted. :rolleyes:
  • DollarDave
    DollarDave Posts: 2,575
    edited January 2013
    Schurkey wrote: »
    ...Tape measure is your friend.
    Agree.
  • pglbook
    pglbook Posts: 2,230
    edited January 2013
    I got my recently-bought SDA 2Bs in my 2005 Camry - one speaker in the trunk and one in the back seat. However, the SDA 2Bs are only 41" tall. They just fit, with about an inch or two to spare on each side. If the SDA 3.1TLs are 48" tall then they will not fit in a Camry. It would definitely be time for a truck.
  • Mystery
    edited January 2013
    Schurkey wrote: »
    DaveMuell wrote: »
    Agree.
    Hehe... I know but I was thinking of going to seller's place during lunch time.
    But after talking to him, there was no IC cable so I have to go home anyways to get the cable from other SDA's plus it was too far to drive during lunch break.
    pglbook wrote: »
    That confirms it then.
    3.1TL's won't fit in Camry.
    I'll have to bring SUV tomorrow at work and make plans to get few hours off during lunch time.
    Thanks.
    Toolfan66 Posts: 17,365
    edited January 2013
    I emailed him last week and told him I would give him $200 cash and he accepted but I had to pass as I don't need them.. So I know you can talk him down..
  • Mystery
    edited January 2013
    Thanks for heads up Larry.
    I'm also bargaining with him but not that low.
    We'll see how it goes tomorrow.
  • Mystery
    edited January 2013
    One thing that concerns me.
    Seller mentioned they are in a barn and last week, temp was below 0. Hope that doesn't mess anything up in the drivers/crossovers. :confused:
  • ZLTFUL
    ZLTFUL Posts: 5,658
    edited January 2013
    It *shouldn't*. Just make sure you let then acclimate to room temp before connecting them and going nuts.
    Overnight is a good idea as it will let the interiors come up to temp as well.
    tonyb Posts: 33,024
    edited January 2013
    Mystery wrote: »
    I would be more worried about the damage done by mice, being in a barn.
  • Mystery
    edited January 2013
    Got them!!! :loneranger: :cool:
    All drivers work including tweeters and SDA driver.
    One passive has small crease on bottom but not a rip.
    Cabinets are black and look very good besides usual scratches, scuffs etc...
    I assume they are painted at some point as I didn't see black 3.1TL's in Polksda site.
    These do not seem as wide as the 2B's but little deeper.
    No IC cable but I took my CRS+ pin/blade and it fits fine.
    Now I need to make a custom cable for one of them.
    Nothing fancy but at least something that can perform same as IC cable.
    My 2B's are not bi-ampable but these are.
    Need to check schematics to figure out what drivers are separately powered. :confused:
    Also, now need to sell either 2B's or RTA-12C to get space back in the room.
    Toolfan66 wrote: »
    Yes, I knew I could talk him down to around $200 but this guy is doing this for a living and I already had send him an offer of $250 that we agreed upon.
    He buys and sells stuffs. His barn was full of stuffs and had a huge poster on the street 'Huge Sale'.
    Plus these don't come too often so few bucks up/down not a huge deal.
    Still in my car.
    2nd and 3rd photos are from the ad.
    So now the question, what's different about SRS vs SDA?
  • tophatjohnny
    tophatjohnny Posts: 4,182
    edited January 2013
    Great deal, Congrats!
  • oldmodman
    oldmodman Posts: 740
    edited January 2013
    Deal of the century!
    I was very happy to pay more than twice that for mine. But I was looking and looking for a pair that was as close to brand new as possible. And they are.
  • Mystery
    edited January 2013
    Thanks!
    I'll clean them up and start a new thread with pictures.
  • Drenis
    Drenis Posts: 2,871
    edited January 2013
    I paid more than double what you did and that was a steal for me. Enjoy although they don't look worth double the price paid.
    Now mod them and don't look back.
    Also, SDA is patented technology that is used in a variety of polk speakers. SRS is a term used for 'Signature Reference Speaker' and was exclusive to only be for the "best" models. These were polks flagship models.
  • pglbook
    edited January 2013
    Congratulations. That is a great deal for a great pair of speakers!
    I am curious - did they fit in your Camry after all?
  • Mystery
    edited January 2013
    Drenis wrote: »
    I'm sure, they'll look much better once I wipe the dust and grime out.
    I'd like to listen to them as it is for a while as they are already TL's.
    All non-SRS have tweeter above the mids and SRS have tweeter in between mids in a vertical array.
    Is that a good assumption?
    pglbook wrote: »
    If you look at the picture I posted above, it's a SUV.
    That was yesterday's question as I drove Camry yesterday and wanted to check them out.
    However, after few replies and some dimensional answers (hehe, different SDA here...), I drove Lexus RX today and no problem fitting them with back seat folded. :lol:
  • KellyMic
    KellyMic Posts: 166
    edited January 2013
    Congrats on a great deal!
    I see you are in Denver, I saw a pair of mint looking SDA SRS 1.2's there last week but he wanted $3k. It was out of my price range but looks like a decent Polk market there.
    Polk Studio Monitor 4.6 Series 2's, Polk RT1000p's, Polk LSi25's, Boston Acoustic VR-975's
    Crown D-75, Crown CE1000, Crown CE2000
  • Mystery
    edited January 2013
    Thanks.
    I never saw those 1.2's but too high for my budget.
    BTW, there is a pair of restored/upgraded 2.3TL's in Loveland for $1200.
    edited January 2013
    I would pull every driver and make sure they are all correct.. Have fun!!
    edited January 2013
    Mystery wrote: »
    Thanks.
    Those belong to Kevin (zardoss) he is a member here but does not come around much anymore..
    Those 1.2's sold within 20 minutes!!
  • Mystery
    edited January 2013
    Toolfan66 wrote: »
    Will do.
    Thanks.
    edited January 2013
    Mystery wrote: »
    Will do.
    Thanks.
    Also do a visual check of the crossovers while your in there..
  • Schurkey
    edited January 2013
    Mystery wrote: »
    Aren't those like some of the early 1Cs? Might need to attach a wire from the negative speaker wire terminal to the currently-unused terminal in the SDA interconnect socket. Then they're AI-1 compatible, which opens up your options for amplifiers.
    Mystery wrote: »
    Define "separately powered".
