under powering MM120???
bobbybibb
I have the Alpine 5 channel MRD-F752 class T Amp. Birth Cert. says it is rated 105x4x358x1 RMS at 12.0 volts. I'm using the front channels to run my MM455 and MM465 at 2ohm stereo (maybe getting 150x2 at 2 ohm 12V). I'm running the rear to my 6x9" Polk dX9. The sub out to my MM120. (the sub output is 358x1) Do you think I'm under powering my MM120?
Post edited by bobbybibb on
